Question about Canon Cameras
Error code 99 has developed on my 20D camera, only this time the mirror keeps rapidly firing, and removing the battery and reinstalling it has no effect,removing and replacing the Canon lens and CF card even sets off the mirror albeit in single stroke movements, its like the camera is live all the time, is it terminal?, please anyone!, thanks, ron.
  • benshiloe Aug 07, 2008
    When switching on my Canon EOS 20D camera, the shutter fires rapidly non stop while flashing in the top panel ERR 99, switching off or removing battery makes it stop, but opening the card door makes the shutter click once, removing the card it clicks once, push the card back in three times, removing the lens fires the shutter three times etc, all with the power off, its like the camera is live all the time, with the battery in! all lenses batteries etc are Canon, ERR 99 has happened before but it never continuely fired the shutter, and all i did to cure the error 99 was remove the battery and put it back in with the camera ready to shoot once again! please is old faithful 'dead'? thanks, ron.
  • 282 Answers
Error 99 also covers mechanical failure of the shutter andprimary/secondary mirror ***'y. I have seen the dreaded err99 when thesecondary mirror wouldn't get out of the way.
This happened at about 6000 clicks. Moving the secondary mirror with my finger fixed the problem. I am now at 8500 clicks
SOURCE
Posted on Aug 07, 2008
  • Canon Master
  • 13,433 Answers
Err 99
Remove and re-install the battery
this may occur if you use a non-canon lens and the camera or lens does not operate properly.
You said you have done the recommendation already and it has no effect.
It would indicate that there is a fault in your camera if the lens is operateing correctly.
You can contact www.advancecamera.com/repair for a free repair estimate. I can't say for sure what the fault may be.
Got warranty?
    Guru:
  • 1,894 Answers
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
    Master:
  • 848 Answers
The solution to this problem is to do a "SENSOR CLEANING" function from within the MENU. Take the lens off, do sensor clean then just turn it off and back on with a lens.
    Genius:
  • 3,422 Answers
  • Priya darshan Aug 07, 2008
    Please click on that link and you will get the solution of your problem.
    Please don't forget to accept the solution.
  • 1,183 Answers
When did the message come in. Does the camera stay on after the error code.
Thank
Proton
  • Mandeep  Singh
    Mandeep Singh Aug 08, 2008
    Hi Ron,
    Below are the steps to help you resolve the problem .Escpecially the last part. Incase the same did not fix the issue .Hate to say this but the camera is dead and need to be either taken in for repairs or replace it with a new one
    To isolate the cause of the issue, we suggest that you do the following:
    1. Turn off the camera.
    2. Remove the lens, battery, and CF card.
    3. Allow the camera to sit without power for approximately 20 minutes.
    4. Insert a fully charged battery, and turn on the camera.
    5. Depress the shutter button as you would to take a picture.
    Does the “ERR 99′ message appear? If it does, then the camera should be
    serviced. If it does not, then please proceed to the next set of steps:
    2. Insert the CF card.
    3. Turn on the camera.
    4. Format the CF card in the camera.
    Does the “ERR 99′ message appear? If so, then the CF card is the most
    likely source of the issue. Try using a different card.
    If the message does not appear, please complete the following steps:
    2. Clean the lens contacts by gently rubbing them with a pencil eraser
    or soft cloth. Be careful that you do not let any debris fall into the
    camera body.
    3. Reattach your lens.
    4. Turn on the camera.
    Thanks
    proton
Error 99 when using Quantum Transceiver
Error code 99 is a non specific error code a sort of catch all. Remove the lens and clean the contacts (lens and camera), remove the battery and the memory card. Leave the camera in this state for about 10 mins, enough time to discharge any build up of charge or static. Reinsert the battery and the memory card and reattach the (cleaned) lens switch on leave for 5 seconds and press the shutter button to see if this has cleared to problem.
Jul 09, 2014 | Canon EOS-20D Digital Camera
What is error 99 in canon eos 20d
It's a frustrating catch all error and needs service.The camera may have any one of numerous issues or lens issues. If you have more than one lens, see if the error occurs with both lenses on. If not then it's a lens error. A camera repair facility can plug unit the camera and download a more accurate troubleshooting code. Royal Camera Service in Hanover Park, IL is good source for this problem. The replaced the shutter on my 20D when I got the error 99 code.
Feb 06, 2013 | Canon EOS-20D Digital Camera
Canon eos 20d error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 20d service manual link:
http://goo.gl/YtVLQR
it will help you to save a lot of money
Hope it helps, Thanks
Aug 07, 2011 | Canon EOS-20D Digital Camera
I got error 099, before I was getting error 05. and the flash dos not open canon EOS 20D
I also get the error 99 message and cannot take any photos... I have been able to solve this problem by taking out the batterys and wiping down the connectors on both the batterys and the connecters in the motordrive with a lens cloth. keep the lens cloth on hand when shooting. It may be that either oils, or dirt has gotten onto the connectors. I hope this helps.
Mar 23, 2010 | Canon EOS-20D Body only Digital Camera
Error 99 message keeps popping up
Hi
I just read that the error 99 problem is a shutter failure and the shutter will have to be fixed. The cost is about $180.
see http://www.mcvr.com/canon_digital_rebel.htm?gclid=CJqG4cvc05oCFRMhnAodCHUA3Q#shutter
ERR99 (error 99) is an indication that there is a communication problem in the camera. It is most often an indication that the shutter needs to be replaced, but it can be the result of other problems. All digital cameras occasionally need to have the shutters replaced. In the days of film cameras, it was rare to wear out a shutter because the cost of film and developing limited the number of times the shutter was cycled. With all those ones and zeros being considered "free" in digital cameras, it is not uncommon to take several hundred or more photos in a day. Even with a live-expectancy of 50.000 to 100,000 cycles, the shutters in digital cameras do reach the end of their life and need to be replaced.
Shutter replacement (usually associated with error code "99"):
  • Replacing the shutter on the Digital Rebel series requires more disassembly than most other repairs.
  • The estimate for shutter replacement is $180 on all EOS Digital Rebel models (depending upon the overall condition of the camera).
  • ERR99 error codes are related to shutter or mirror operation and are usually associated with a defective shutter. Cameras that have had heavy use may have shutters that have reached life expectancy and need to be replaced.
May 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Feb 19, 2009 | Canon EOS-20D Digital Camera
Cannon Eos 400D Err 99?
Error 99 is a NONSPECIFIC error message. It is almost always associated with the LENS. I first got this error on my EOS 20D whei I tried to use an older Sigma zoom lens (7 years older than the camera). I don't use off-brand lenses with my Canons. Try removing the main battery first followed by the time & date battery which is hidden in the battery compartment beside the main battery. This will reset your camera. Good Luck!
Nov 30, 2008 | Cameras
Err 99
this is what the canon people say to do for error 99
Read this!!!
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked eaaa19b.jpgb9433a1.jpggood luck!! have a nice day :) :) :)
Aug 07, 2008 | Canon EOS-20D Body only Digital Camera
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error report 99 on my Canon 20D
take out battery for a few mins and that resets the error, well it worked. or Before I reset it, take off the lens and put it back on.
i heard that some have problems with the lexar cards.
http://www.lexar.com/support/cust_advisory.html
in short, format the card every so offten in the camera and see if that fixes it.
also
try a firmware upgrade if your 20D has highest version get this at canon website
Feb 22, 2008 | Canon EOS 20Da Digital Camera
Cameras Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
