Question about Sony Playstation 3 (PS3) Console
My xmb wont come on
When i start up my ps3 it goes straight to the game the xmb doesnt show up and wen i try to access it from the game it goes to the blank screen on the tv now i cant get a system update so i cant play online what should i do
  • sushiswiper Jan 24, 2009
    i have the same problem. it worked fine two days ago when i last played. did you knock the PS3 around at all? like did you transport it or move it somewhere?
    Problem Solver:
  • 5 Answers
If you have a update 2.41 then thats why its not showing get the update 2.42 or go to settings than system settings and turn of auto game start so when you start the system it won't go striaght to the game
Posted on Aug 09, 2008
Have you tried ejecting the game disk?
Your ps3 may be configured to automatically start a game if there is one in the machine.
If you start the ps3 without a game in the drive what happens?
Posted on Aug 08, 2008
Update ure system software
Wont read game discs
Start small; check the game disc/discs. Can you confirm that the disc works? (Try it in another PS3, for example).
Next restart the PS3. Then shut down the PS3, unplug it from the outlet then plug it back in.
No progress? Make sure your system is updated. Who knows, maybe it's a firmware thing. Goto XMB > Settings > System Update and run it.
Still have problems? Now we get technical. First I would suggest backing up your data, as things can and will get deleted in the next couple of suggestions. Use the Backup Utility (XMB > Settings > System Settings > Backup Utility) to store everything. You can then restore all your data later on.
With your data backed up, try the different options in Safe Mode. This link will show you how to access it. Try options 2, 3, 4 and 5, in that order, and see if it's reading discs in between each one. Anything after 2 will delete your data; thus the need to make a backup.
Still no luck? Unfortunately this you're probably going to have to send your console in for repair. Sony provides a form on their website to request a repair; here's a link. If you're under warranty it's free; otherwise it's expensive (150$ I believe). The worst part about this option is they take forever; you won't see your console again (or it's replacement) for at least a month, more likely two.
Hope this helps you get it working soon!
Mar 23, 2011 | Sony Playstation 3 (PS3) Console
My ps3 wont read any disks
I had a similar issue.
Backed up and then reformatted the PS3, problem solved.
You may also want to try this to make sure it's not a laser problem:
Load up any downloaded game (or demo), when in the game press the PS Button and you should now be able to see the Games Disc show up in the XMB.
Aug 26, 2010 | Sony Playstation 3 (PS3) Console
Game is in Ps3, wont eject, says no game in the xmb screen
if the disc is spinning with some clacking noise then its all right,use the manual eject button 3 to 4 times.Now the disc should be sited on the disc plate.If you think that this works but not through the software then update the firmware.On new slim PS3 disc stuck,it doesnt void your warranty.
Thanks for using Fixya
Jul 02, 2010 | Sony Playstation 3 (PS3) Console
Wen quit game,,sceen goes blank,,so can acess
this could be many things, one thing i would do, is delete items i no longer use, and when Quiting a game I would try ejecting the disk to see what happens..
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
My PS3 reads and plays movies but when i put a game
give the laser a clean an if still no joy you will have to look at gettin a new laser. http://www.youtube.com/watch?v=E2_j6P82O8Y try that test while you have it apart to see if the lasers behaving properly before you by one tho
Mar 13, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont start up when i switch it on it goes straight off aga
My ps3 wont start up when i switch it on it goes straight off again.
Sep 13, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont show game in menu
It's a problem called blu flu I think. It can't be fixed. You should ring up Sony and they should dispach a replacement for you.
Aug 28, 2008 | Sony Playstation 3 (PS3) Console
Wont run correctly
It sounds like a system file error due to trying to hack background, so check the CSS template and the theme.css to see if they are present in the theme folder. You will have to take hdd out and run on a pc to do this, you can find how to remove hdd by looking on search engine. If you get a 403 error, that means you are not allowed access. You will have to delete and reload the file from a known working ps3 hdd.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
313 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
