Question about Sharp AL 1215 Black and White Copier
Error code L1
I have tried the 2 solutions posted. Neither one worked. Can you help me?
Jason 404.456.7013
  • Sharp Master
  • 2,794 Answers
There is lock located on the bottom of the scanner on the left side. Make sure the knob is in the unlock position. If it is, then there is plan B I can tell you about.
Posted on Aug 09, 2008
SOURCE:
What does error code L1 mean on my chigo air conditioner unit
When posting hardware questions, it is useful to post brand and model number. There are a number of Chigo air conditioners. I have examined an error code page for the brand and the error L1 is not listed. However, on page 25 of the following manual, L1 is identified as a current transformator of which there can be a No-voltage for over-c
urrent detection circuit. See 4) Electric control panel detection sub-number 3 on that page.
http://www.investliving.se/upload/images/Produkter/Luft-Luft/New%20Basic/Service%20Manual%20New%20Basic.pdf
Dec 18, 2017 | Heating & Cooling
What is error code f69 on a frigidaire electric range
Hello. You have a serious problem--that error code means L1 or L2(the 120v supply wires) may be shorted with the neutral on the incoming power supply. TURN OFF THE POWER!! Check the wiring at the terminal block. The neutral is the center post. L1 is usually black and L2 is usually red. The F68 and/or F69 error means high voltage or the above-mentioned condition. Once you have verified there is no incorrect polarity or voltage condition, then the main oven control board must be replaced. The part number you might need is 316562011. I hope I helped you!
Sep 20, 2015 | Frigidaire Kitchen Ranges
Canon ir6000 giving error e225
Error code E225 on Canon
1. CIS lamp is bad.
SOLUTIONS:
1. Turn the power OFF and then back ON.
2. Replace the CIS unit.
Oct 12, 2013 | Canon iR5000-6000-L1 PS Ver 1.0
Error code L1- what is this and how to fix
You did not post your make and model number but if it is a Sharp or Toshiba try my service top for this problem. If it works for you then please retun to this post and provide feedback.
Thanks,
WheatlandServices
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
Dec 21, 2010 | Office Equipment & Supplies
Hi.my name is jason .i have a mitsubishi,ws 55511 integrated hdtv. the pictue is excellent but it comes on for only one min but turns off after that,what do you think the problem is and how much is it to...
WHEN it shuts off and the power light goes off try this:
On front of set press and hold both menu and input buttons at same time for at least 5 seconds and release both.
Power light should blink 2 digit error code like: 2 blinks, 2 blinks, a pause and repeat it 4 more times.
Let me know error code and I will tell you what if anything it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 21, 2010 | Mitsubishi Televison & Video
My sharp AL 1551 CS is getting a L1 error code before that it was getting a E7 code. The scanner will light up and shut right back down, then it shuts itself down again.
I have a tip posted here on Fixya that will help you diagnose and repair an L1 failure code on the Sharp AL series copier.
Here is the link:
If this works for you then please return here and give me positive feedback.
Thanks for using Fixya today.
Jul 13, 2010 | Sharp AL-1551CS Copier
Sharp al 1661 cs ..it shows System error(L1-00
I have posted a tip covering this code here on Fixya. Here is the link to it so that you may find a solution for your L1 code.
Good Luck and Thank You for using Fixya.
Jun 10, 2010 | Sharp AL-1661CS All-In-One Laser Printer
I can't beat the part on grand theft auto for ps2.
One solution is to get better at the game. Another is to take a sample from this cheat list:
(L1 and R1 are Left and Right triggers respectively)
Weapon Set 1
UP, SQUARE, SQUARE, DOWN, LEFT, SQUARE, SQUARE, RIGHT
Weapon Set 2
UP, CIRCLE, CIRCLE, DOWN, LEFT, CIRCLE, CIRCLE, RIGHT
Weapon Set 3
UP, X, X, DOWN, LEFT, X, X, RIGHT
Restore Armor
L1, R1, CIRCLE, L1, R1, X, L1, R1
Restore Health
L1, R1, X, L1, R1, SQUARE, L1, R1
Wanted Level Never Appears
L1, L1, TRIANGLE, R1, R1, X, SQUARE, CIRCLE
Weather: Sunny
L1, L1, CIRCLE, R1, R1, SQUARE, TRIANGLE, X
Spawn Rhino
L1, L1, LEFT, L1, L1, RIGHT, TRIANGLE, CIRCLE
Slower Gameplay
R1, TRIANGLE, X, R1, SQUARE, CIRCLE, LEFT, RIGHT
Perfect Traction, Down=Car Hop
L1, UP, LEFT, R1, TRIANGLE, CIRCLE, DOWN, X
Cars Drive On Water
CIRCLE, X, DOWN, CIRCLE, X, UP, L1, L1
Cheat: Infinite AmmoEnter CIRCLE, SQUARE, L1, L1, TRIANGLE. Submitted by RCOOL93 Cheat: Disable Collision Damage UP, UP, UP, L1, L1, R1, R1, UP, UP, UP.
Jan 15, 2009 | Sony PlayStation Portable (PSP) Console
Sharp AR-5127, the error code U2-40
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL 1215 Black and White Copier Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
