Question about IRISPen Express
Output worsens every time I scan
Dear Expert,
I have an IRISpen executive and an iBook G4.
Here is my problem: I calibrate the scanner, scan the text, and then the output is sort of acceptable. Then I do it again, and the output worsens instead of getting any better. It's like my scanner has a negative learning curve... what do I do wrong? The scanner is basically useless.
Thank you very much for your help!
Marie Muschalek
How do I reconnect to the internet, I restored my iBook G4 to factory settings and although I am connected via Airport am receiving an error message that no ports are open . Everytime I try to open T
The pointer jumping on the screen sounds like you may have picked up a virus. While rare, there are mac viruses. I would try to save all my data documents and any other valuable personal files or lists, then do a clean reinstall of the operating system. Then load our documents back in.
You could try to scan for a virus with a mac virus program, but not many are available for a G4 Power PC (PPC) machine.
May 10, 2014 | Apple iBook G4 Mac Notebook
My canon lide 700f will not calibrate to scan a 35mm film
For those having the "Executes calibration. Pull out the film and place the Film Adapter Unit at Frame 1." issue and cannot calibrate the scanner for NEGATIVE FILM, it took me ages to figure out how to solve it.
Solution: calibrate the frame, WITHOUT any film, adapter plug and placed in frame 1, and proceed to do the calibration WITH THE SCANNER COVER OPEN.
Before I tried everyhing, install new drivers for Windows 8.1, MP Navigator, and nothing happen. Now it works like the first day. Hope it helps! it certainly helped me.
Jan 29, 2013 | Canon CanoScan LiDE 700F
Irispen II driver
try this link to retreive your driver for which is compatable to windows 7
http://www.driverssolve.com/sw/69135.html
Aug 01, 2010 | IRISPen II Executive Handheld Scanner
My apple ibook G4 cant boot operating system. Whenever i on it, it will only display a folder with question mark on it. Pls what can i do. I am a nigerian.
The folder is a sign that there's a problem with the system software. Reinstalling the system software should allow your iBook G4 to boot up.
Apr 14, 2010 | Computers & Internet
How do you calibrate the scanner bulb? I get a "Check SPF/RSPF" error message when trying to scan a document through the auto-feed tray and a local service company said that the scanner bulb needs to be...
The Calibration of the scanner and calibration of the monitor - a complex process. Prcess requiring special equipment and experienced specialist. Not advantageously buy high-priced equipment for Calibration of its one scanner and monitor. If work high skilled, you it is necessary to return in service for calibration if you want this execute themselves, recommend to build apart monitor on test list, but then on test table by means of regulations adjusting the scanner on colour and density of the scene to build scanner
Sep 24, 2009 | Sharp AL-1655CS Copier
Downloaded all the drives and still can use it as the message:"execute appliation" keeps poping up
You need a scanner application such as Adobe Photoshop or other program.
Cannon has one for your scanner at this link.
http://software.canon-europe.com/products/0010399.asp
May 24, 2009 | Canon CanoScan 4400F Flatbed Scanner
Pentax DSmobile 600 scanner cuts off image
Try recalibrating it. If you don't have calibration sheets, buy them at:
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Jul 30, 2008 | Pentax DSmobile Path-Through Scanner
IRISPen Express Logo
65 people viewed this question
Top Iris Office Equipment & Supplies Experts
xalint1
xalint1
Are you an Iris Office Equipment and Supply Expert? Answer questions, earn points and help others
