Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Broken Cabel Connector RCA 52 HDTV
Hi I have the same problem soem of the other I have a 52 inch wiedescree RCa HD tv which aitn woirh of **** if you aks me teh Tv has a broke cable connection for the last two years although it shows very nicely picter except since its been tunign through the dvd/vcr it will not pick up the teh chnnels tha hs went digital.. Can this connector be replaced or fixed?...
  • 2 more comments
  • Anonymous Feb 01, 2009
    the cable connector broke off and we are trying to repair it ourselves, don't have the 150.00 tec says it will take for him to fix it? is there a liquid soder? that can be used???????? HELP!!!!!!!!!!!!!!
  • gregruth Mar 12, 2009
    i have the same problem mine is broke all the way off and its in a box so what do u do if that happens
  • Anonymous Apr 22, 2009
    rca 53 inch has lines on top and bottom and also lots of lines on screen color discoloration..... dont know whats wrong any solutions other than junk i?
  • cindynp Apr 22, 2009
    rca 52 inch has lines on top and bottom and also lots of lines on screen color discoloration..... dont know whats wrong any solutions other than junk i?
    Genius:
  • 1,030 Answers
Depend on how badly damage it might be.. as a tech i replace these all the time.. if you can solder it might be possible.
Posted on Aug 08, 2008
Broken front plexiglass rca 52 inch tv
Hello
Contact the nearest authorised service center for RCA at your town.
Mar 06, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52"
This happens all the time. It just might be fixable. This connector is known as the "f" connector or female coaxal connector. Most average electronics technician can fix them. This connector is attached to a component called the tuner. The tuner is what takes the signal and selects the channel the tv recieves. To replace the connector it means removeing the cuircit board that the tuner is on and then removeing the tunner, disasembling the tuner. Now until you find a good tech, there is another option... take an vcr and use the rca inputs on set. essitally tunning the set through the vcr. Now you will have to change channels through the vcr. but it will work. also there is a chance that the tuner might be damaged. just depends on the damage that occured when the connector was broke off..,let me know if you need any more help
Jun 03, 2011 | RCA HD52W56 52" Rear Projection HDTV
You can"t get it to turn on. It is a RCA 52" HD
Replace cp120 & cp150 on the board to the left, known as the deflection power supply.
Dec 20, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hd channels not showing
Your tv has a input named COMPONENT to make work this input you need three RCA conectors (RED GREEN BLUE) plus two audio RCA Conectors red and white. If you have another set that can be plug in in this input and that set (dvd recorder, in ex.) has a digital tuner then you got it, But the Magic about the decoder box is that only cost 40.00 +- dllrs and send the signal to your antenna connector or RCA analog conector. Good luck!
Mar 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA HDTV Cabel Connection
HD doesnt come over the coaxial cable into the TV. It has to use HDMI, composite (5 color RCA cables) or DVI. they can all be soldered back on if you ripped one out. easier to use another input if you have multiple formats back there.
May 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
HDTV picture problems
Does the picture just get dark or does the picture go out completely? Does it do this with both the cable and the DVD? Is the audio affected?
Jan 30, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv screen
try, mcmelectronics, vancebaldwin.com, tritronics
Oct 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
168 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
