Question about HP Photosmart C6180 All-In-One InkJet Printer
HP c6180 pls: need urgent help for error msg 0xc18a0101 Thanks a lot
    Scholar:
  • 169 Answers
Follow this link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en
if it does not work try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
Posted on Jun 20, 2009
  • 4,041 Answers
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
"Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0101 Turn power off, then on again."
The first problem is you have an ink jet consumer printer. Go to their support site and search that error code. That may help, but don't count on it. HP is notorious for selling defective products and have lost more than one class action suites. you can try these steps http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204785&tmp_track_link=ot_search
But it could also be the error for when the ink resovors are full in the bottom of the machine. It will stop working by design then. If it were to over flow you would see where all that ink went you been buying, so they stop the machine before that happens. Best advice is take it to the nearest dumpster and deposit it inside it, and buy a laser printer. It was the best thing I ever did.
Jun 17, 2014 | HP Photosmart C6180 All-in-One Printer,...
I have an HP Photosmart C6180 All-In-One, The message on it reads Error 0xc18a0101. It will not allow me to print. It says that there is some ink problem. What do I do to fix it?
An ink system error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Aug 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
C7280 error msg 0xc18a0101
You press # * at the same time...... with the navegation arrows you go up to system configuration, with the arrown you navegate until you see error report...then you clear the error report.....then you turn off the printer...unplug everything from it.. unplug ac adapter from the wall wait 1 minute... then plug power back....turn on printer an Voila...is working
Jul 22, 2009 | HP Photosmart C7180 All-In-One InkJet...
Ink System Failure Error: 0xc18a0101
hiii
You have to check ur printer connection status if it is ok then you can restart the printer and run it again on your system.
and if still your problem is not solved then can visit for free technical support on http://techbuddies-robin.blogspot.com/2009/06/free-technical-support-regarding.html
Jun 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
454 people viewed this question
Seeker5211
Seeker5211
