Question about Nikon Speedlight SB-600 TTL Flash
Water got into my sb600
Sonehow water got inside the sb600, batteries got hot, but nothing switched on , any solutions?
I agree, sounds fatal, but let me know the outcome. I need the hotshoe off of a broken one. My electronics are OK but the hotshoe bracket is broken on mine. Email me at [email protected]
Posted on Aug 11, 2008
  • 667 Answers
I doubt it. Water damage usually is fatal, or very expensive.
Posted on Aug 08, 2008
SOURCE:
My NIkon SB600 is stuck on my hotshoe-I can not remove it fromt the camera (d80) help
I had a similar problem with my SB25 when I tried to use it on a D90. I took the camera into the Nikon USA Repair Depot in Los Angeles where they took it into the back shop and removed it while I waited without charge. If the SB600 is like my SB700 and SB900's, there is a spring loaded dimple in the camera's hot shoe that clicks into a hole in the SB flash hot shoe. I think if you can slide a thin piece of metal such as a machinists shim, you may be able to depress the dimple and release the SB600. Let me know if it works.
Mar 15, 2011 | Nikon Sb600 Sb-600
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Canon d60 - Built-in flash will not pop up
There may be something obstructing it from popping open. Inspect the flash area carefully. You could remove the battery and put it back in to see if it corrects the problem. Also, check the flash settings in the menu to make sure that the flash is set to operate. If all of those fail then take the camera in for warranty repair. If the warranty has expired and nothing else works I would suggest getting an external flash for you camera. You will be amazed how much better your photos come out using an external flash. If you go that route then I would suggest going to a camera shop or department to make sure the flash will work for you before purchasing. If you just want a small flash a little better than the built-in, get the SB400. It's only around $125. The SB600 is much better, but will cost almost twice as much (but I think it's worth it).
They work beautifully in auto, but the SB600 will reach much farther and give you less red eye. Good Luck you have a great camera!
Nov 10, 2009 | Canon PowerShot EOS D60 Digital Camera
Nikon sb600 flash
Auto zoom only works when on the hot shoe of the camera. You also need to make sure that its in the righht mode (make sure that above the word Zoom on the display it doesn't have a "m").
Oh and of course you have to have a CLS (Creative LIghting System) compatible camera.
Sep 07, 2009 | Nikon Speedlight SB-600 TTL Flash
No coffee.....but hot water spiggot is OK.
yes there is clogged inside its either the hose or the keypad / connection of the control is corroded.
Mar 09, 2009 | Bunn CWTF15-TC
Stink
Run a solution of hot water and vinegar in your tub on a full cycle using the hot and cold use about 1 cup of vinegar. Just stale water that always sits in the bottom of the washer
Jan 13, 2009 | Amana ALW480DA Top Load Washer
Sb600 display fine, but no longer flashes
Your flash has a bad flash tube . make sure the batteries are in corectly and youhave a ready red light .
Nov 08, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 flash menu locked.
Nikon hot shoe is rated up to 250V (canon's is rated up to 6V) so you can use almost any tipe of flash, except maybe for old studio flashes.
Vivitar 283 (older versions) is ~200V rated, and much lower on newer versions. It should work.
Apr 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
166 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
