Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Door locked light is staying on and door will not open
    President:
  • 1,462 Answers
Possible machine has not drained - this will prevent door opening.
put drain hose at floor level into a tray and drain that way then switch off at mains, wait 3 mins and see if door opens
Posted on Aug 07, 2008
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
Door open indicator light stays on , automatic door locks go on & off while driving and dome light and outside mirror lights wont go off after the car is turned off
i would hazard a guess and say that wires in the rubber boot from the door pilar to the door are damaged or the connection block in the door pillar in this the terminals are corroded or something similar
Nov 22, 2011 | 2002 Mercury Sable
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door open indicator stays on and lights stay on and car won't lock
One of the doors "thinks" it is open.That will make light stay on, power door locks will not operate and alarm will not arm itself. If the indicator shows which door is open, then check on the door frame for the door ajar pin / switch. Move it by hand repeatedly to see if it is stuck or misaligned. If unable, then pull the pin out to check the connection, and if still no help, then bridge (short) the cables to see if dome light goes out. If this is the case, then replace the pin.
May 19, 2010 | 2006 Volkswagen Jetta
1998 Ford Windstar fuse problem - dome light stays on etc
you most likely have a bad door ajar switch- the door panel has to be removed to access it, its on the door latch- you can unplug them this will take care of the batt drain prob.as for the locks it may be a switch problem- most ford vehicles will not let you lock the vehicle from the driver's door when it's open to prevent locking the keys in.
May 26, 2009 | 1998 Ford Windstar
Dome light and doors open light stay on when driving.
check you door switch buttons to see if they will each turn off the lights. Open one door at a time, push the door push button by hand and see if the lights go out. If they do, that is your probelm switch or the door is not closing tight enough to psuh the pluger button all the way in.
Apr 25, 2009 | 1999 Ford Taurus
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
78 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
