Question about Samsung Digimax S800 Digital Camera
Turn on camera,shows format
After pressing the OK button,
it shows Check SD card;
no immage any thing
    Problem Solver:
  • 7 Answers
Remove the sd card and insert it firmly if not workin service the sd card slot
Posted on Aug 07, 2008
Format sd card intova sp1
To format your micro SD card in our Sport HD II camera model SP1 N, please press the menu button in either video or photo mode, press up or down arrow button to select setting icon, press OK, press down arrow button 5 times to highlight "format", press OK, press up or down arrow button to select YES and then press OK to perform format. Please note that format will erase all data from your card. if you have further questions, please contact Intova by phone, (808) 837-0074 or email shallyn@intova.net .
Thanks,
Intova
Oct 05, 2013 | Intova Video Cameras
Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 | Megxon X33 Digital Camera
Keep getting ( check sd card ) prompt no matter what I do.
Are all three cards 2GB and smaller? Cards larger than 2GB are actually SDHC cards and will not work in the D53.
Mar 08, 2012 | Samsung Digimax D53 Digital Camera
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
The memory card cannot format rejects reformating
You card might be faulty or not supported by this model.
The memory card support for V610 is SD/MMC up to 2 Gigabyte
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button
Jan 25, 2010 | Kodak EasyShare V610 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
2. Press the MODE button twice to enter Playback mode. Then press
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
Lumix DMC-LC33 shows memory card error -format this card? Yes or NO..no matter the Sd card , if select yes- no results, if select no - no results.
This normally happens when the memory card gets corrupt. Hope you have pressed OK after selecting YES. Check whether the card is locked. SD card has a small Lock button on the top left. If this fails, buy a new SD card and format it in the camera before taking any image.
Dec 13, 2009 | Panasonic Lumix DMC-LC33 Digital Camera
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Card will not format
memory card? and SD card? whatever the card hook your camera to a usb to computer and find it under "my computer"
look at all your drives you should have like c, d , e, f, g, h, select the last drive and see if it finds your card if so try formatting it through the computer, whatever you do dont select c or d to format. if problem persists buy a new SD. I find good deals on ebay or Walmart.
Dec 23, 2007 | Samsung S850 Digital Camera
Cards not working with camera
If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung Digimax S800 Digital Camera Logo
122 people viewed this question
Top Samsung Cameras Experts
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
