Question about Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher fifteen eighty five is the model
Where is the power from the panel connect to the dishwasher. I can not find where you connect the ground, neutral, and hot wires. I have looked in the back of the dishwasher and I see the wires connected to the various components, i.e. the little built in garbage disposal, the pump, etc. please tell me where to find the wires to connect from my panel.
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Posted on Apr 08, 2008
SOURCE: Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Posted on Jul 24, 2008
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
Posted on Apr 11, 2009
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
Asko fifteen eighty five dishwasher completes cycle, but the drain cup area still has water in it.
The drain cup normally has water in it after it drains. The pump runs it empty, but when it stops, some water runs back down from the drain hose, which you see in the drain cup. If there is water in the bottom of the tub, you may be having some siphoning coming back after draining. Check to make sure the drain hose has been routed up to the bottom of the countertop as per the installation instructions. That's what prevents siphoning, and its very important so it doesn't suck sewer water back in with the clean dishes!!
Jul 08, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
I have an asko d3251 dishwasher that won't stop running. The device in the drain that spins won't stop. I had to shut the power off to the unit.
Our unit had leaking connection on outlet side of fill solenoid valve. Any leak will cause water to accumulate in base pan. there is a float switch in base pan as a safety mechanism when water is in pan it causes a styrofoam float to rise and make contact with switch. This tells machine there is a leak creates error code to run pump continuously until water is removed from base. Disconnet electric from unit first. you must pull dishwasher out to get at back panel. Remove lower back panel to get access to mechanicals of unit. Once you remove panel you should see water in pan. If you see water that is most likely same issue we had. soak up excess water or tilt unit to drain water out of pan. once water is gone unit should start normally. If you look underneath while unit starts up - don't touch anything while unit is connected to electricity! You should notice where water is coming from. Our unit leaked at hose connection from outlet side of solenoid fill valve. connector is a plastic cam-lock fitting with a flow sensor integrated into it. there is an o-ring between the two parts. it comes apart with a very small amount of counter-clockwise motion. perhaps only five or ten degrees of indexing and it falls right off. it is a very flimsy connection for the main water line. the o-ring on our unit Was slightly deformed and not seated correctly. could have been from original installers 4 years earlier! Asko needs to re-design this part. I replaced o-ring and unit is working again however I do not trust that this fitting will hold up over time. Very poor design in my opinion. Other design flaw I noticed while looking at mechanicals is circulating pump isolation mount is not in correct location for pump motor. rubber mount is stressed to the point of almost tearing off! No way for me to correct this since location of mount does not match position of motor. We will not replace this unit with another ASKO when it goes.
Jan 19, 2013 | Asko D3251HDSS Stainless Steel Built-in...
Water Connections
In the US dishwashers are usually connected to the hot water supply. Although the ASKO 1850 I believe has an in line heater. Using hot water supply will reduce electrical useage.
Interestingly we use to have ASKO washer and it suggested only using cold water hook up as it heated its own water. I guess this was a feature if one's laundry area does not have hot supply, but it made no sense in CA to heat water with electricity.
Nov 11, 2009 | Asko 24 in. 1805 Built-in Dishwasher
New Asko Dishwasher. Both the appliance store
Make certain the door switch is making contact and the switch is good. Open the front panel and trace all the wires,especially where they go from the door to the underside of the DW. Look for a broken or pinched wire.
Jul 06, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Apr 06, 2009 | Asko 24 in. D3121XL Free-standing...
Can't get my Asko D3232 to start
Try flipping the breaker off and on. If that does work it maybe the control panel.
Sep 25, 2017 | Asko TouchProof D3232XL Stainless Steel...
Wash temperature scale
TEMPERATURE - CELSIUS OR FARENHEIT
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
Sep 22, 2008 | Asko W640
1502 NO POWER TO PANEL
The wiring diagram is INSIDE the metal casing behind the lower kick panel. It is a paper schematic that details the wiring of the dishwasher. Mine was pretty water logged and crusty. Just unscrew the kick panel. It should be right behind it
BTW: Ours also lost power to the panel last week. It's interesting that the production date of our Asko is from 1988. Exactly 20 years. Asko's warranty is also exactly 20 years. Coincidence? Don't bother trying to replace the board. Asko discontinued it and it is no longer available.
May 18, 2008 | Asko Dishwashers
Asko dishwasher model 1475
Have the same problem with our asko 1475. In the past, we would disconnect the dishwasher and when we reconnected the power, it ran fine. This time it isn't helping!
Nov 08, 2007 | Dishwashers
Asko 24 in. D3250 Built-in Dishwasher Logo
318 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
