Question about Canon Office Equipment & Supplies
THE WHITE PAPER TENTION ROLLER AND SPRING FELL OFF THE COPIER...I CAN'T FIND WHERE THEY CAME FROM..
  • phonelinej Aug 08, 2008
    CAN' FIND A GOOD PICTURE TO TELL ME IF THE WHEEL GOES IN THE PAPER CARTRIGE OR ON THE MACHINE ITSELF.....THE WAS ALSO A SPRING FOUND WITH THE ROLLER ARM.............
    Novelist:
  • 158 Answers
Try going to www.usa.canon.com. Search for your model on the sites search bar. If your model is found, you can activate a viewer whuch shows machines from various angles, and can be enlarged. You may be able to determine from one of the views where the roller goes. On the same site, you can contact canon technical support,. They may also be able to assist you, or recommend a service center near you.
Posted on Aug 07, 2008
SOURCE:
Is there a specific type of oil used for the rollers
open Tray 1. Remove the paper feed roller. Remove the separation pad under the feed roller. You will see a small spring. Try to cut JUST ONE ring of this spring.
Aug 07, 2014 | Ricoh Aficio Mp 171 Copier
Dowenload error e20
You may have the movement of a paper shift roller blocked by something. Or a spring is popped out on the white plastic roller that rides above the black roller (the one that shifts in the attached drawing). Or the motor itself is bad.
Dec 13, 2013 | Ricoh Aficio 450 Copier
I have a Canon PC 3 II, It is a small portable black only copier. It will pick up the paper and take it to the delay gate. The main drive of the copier will begin, but the gate doesn't drop to allow the...
I dont know what you mean by delay gate, but by your story I pressume that paper stucks on registration roller ( metall roller beneath the drum unit ), most common faulty is that spring that holds down the roller snaps, and one side is up.
If these is the case, hook the spring on plastic nose on one end and other end screw with the nearest screw.
Hope that helpes!
Aug 09, 2010 | Canon ImageRunner 2020i Copier
I am getting the message Joo what could be my problem?
not takeing paper from cassette the first sensor from pick up is durty or the actuator spring one the sesor is hooked out it is setuatedjust unther the drum unther the white registration gaide roller to remove it to remove it remove the image unit remove back cover remove registration clutch remove white registration roller clipout the sensor
Jun 25, 2010 | Kyocera KM-1505 Copier
Help!
This roller is actually the registration roller. Most often what happens is the plastic tabs that hold the pressure springs break. At either end of the roller there should be a plastic block along with the white lever and spring that runs between the 2. If either of these springs is missing then the tabs have broken and the spring has come off. The reason the paper stops is there is insufficient pressure to pull the paper thru. You need to check both sides and determine which of the 3 parts per side that you will need. You can order them from precisionroller.com
They have pictures of the parts so you can see whch ones you need. Just search for "Canon PC430 registration" at you will see the pics of the parts you need.
Good Luck and Thank You for using Fixya.
Jun 02, 2010 | Canon PC-430 Color Copier
Canon PC770 - paper tray wouldn't slide in all the way
Thats right that spring help to counter balance the top,the pease of plastic is to keep the spring in place.There are 2 spings that support the top.That plastic is not so expensive but to install the new plastic and spring is a very big job and it can be expensive.It normally takes me 3 hours to replace.The mashine can work normally it is only a hassel when you want to replase the toner .
Jun 16, 2009 | Canon PC-920 Black and White Copier
I have a Canon 330 Home copier, and the paper drive, sprang the spring on the left side, and the paper goes in crooked. Where may I find a repair service, In Shawnee, Kansas 66216
i am assuming you are talking about the spring on the sponge roller under the drum you can use a small spring like from a pen just cut it in half or so.. that is if you have the little bushing that goes over the roller shaft.. ( the same set up on bothsides) the put tape it to hold it in place
Dec 26, 2008 | Canon imageRUNNER 400S Copier
The paper won't feed
Some times need to clean "paper roller" with water-based cleanser with white fabrics or rag. The reason of this problem often is paper dust. The paper roller have excentric shape and you must to clean biggest radius of contact sphere of paper roller. To do this you must to interrupt rotation of roller, then printer try to pick up paper, by "power off" printer.
Jun 29, 2008 | Canon PC-940 Black and White Copier
My copier makes a noisy sound
Check the crumpled paper. If it has an image, it has reached the drum and is crumpling at the fuser unit (part that gets hot). If that is the case the fuser gear and drive gear need to be replaced.
May 01, 2007 | Sharp AL 1215 Black and White Copier
Open Questions:
Canon Wireless Printer Tech Support pHoNe%%[+l26O{0O64}^]:~%%NumbER Wngjsery Canon Wireless Printer TeCh SuPpOrT Number +[185526O{0O64}]WngLogin Canon Wireless Printer customer service phone Number Repair service center to resolve all Canon Wireless Printer products. Canon Wireless Printer is an American multinational company which was founded by Michael Canon Wireless Printer using its company headquarters in Round Rock, United States of America. Contact Canon Wireless Printer for Setup & Installation Canon Wireless Printer Setup Free & Installation Canon Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Canon Wireless Printer Connect, Canon Wireless Printer TECH Free Phone Number you'll be searching out Canon Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to Canon Wireless Printer Connect. Get Canon Wireless Printer Setup Instant Free Canon Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Canon Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 19, 2019 | Canon Office Equipment & Supplies
Clive
Clive
old marine
old marine
Ekse
