SOURCE: jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
SOURCE: Is there a bluetooth firmware update for the
KD-BT1 does not support anny form for firmware opgrade and after 20 pairing there will be problems for further parring. JVC have no solutions on this...
SOURCE: no se como activar el
Que tal.
Aquí puedes encontrar el manual en ingles espero te sirva.
Saludos.
Manual
Puede que sea la junta TCON. Si un zumbido o sonido al hacer clic tambi?n puede ser la tarjeta de alimentaci?n.
