Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Travel limits done every thing it says in the book. can not seem to get it to remember where i need it to stop.light keeps flashing to say it has not remembered
  • Anonymous Feb 27, 2009
    same problem..my is a chamberlain...just bought it..it will open up and stayed up. When i use the remote it make 2 click trying to keep going. everything seemed lined up and good..Please help. thanks.
  • Doorguy27
    Doorguy27 May 11, 2010
    Need a little more info. Are you trying to set the limits of your new garage door opener? lights are flashing? What brand is the opener?
  • 4 Answers
Unplug the unit before setting codes for travel or stops for travel then plug back in
Posted on Apr 04, 2009
The motor runs but the chain does not move, we just had it worked on 1 month ago and now this, please help
IF THE MOTOR IS JAMMED (JUST HUMS) LOOSEN THE CHAIN AND ADJUST THE LIMITS AND TIGHTEN CHAIN.
IF THE MOTOR ACTUALLY RUNS AND THE CHAIN DOES NOT MOVE THE DRIVE GEARS NEED TO BE REPLACED. THEY SELL A KIT THAT INCLUDES THE BUSHINGS AND SHAFT. DO NOT BUY THE SMALLER KIT AND DO NOT REPLACE ONLY ONE GEAR (THE OLDER WORN GEAR WILL CHEW UP THE NEW GEAR) THIS MAY BE WHAT YOU HAD DONE - IF SO CALL THE SERVICE GUY THAT DID THE POOR REPAIR AND HE SHOULD REPLACE BOTH GEARS UNDER HIS SERVICE WARRANTY. ANYONE WORKING ON THESE SHOULD KNOW BETTER.
GOOD LUCK.
STEVE
Dec 14, 2014 | Sears Craftsman 13953754 Wireless Garage...
Tv lift does not raise to proper level the details below explain all this
Dear Ted
Sounds like the stop limit is incorrect. There are three possible ways motors establish a stop limit. The most common is a limit switch(a small black box with a lever or button that sops the motor when this lever/button is activated). There are two one to stop on the way up and one on the way down. If this is the case then the up switch is being pressed too early something might have come loose and is now activating this switch early. The second way is through electrical current monitoring. When the motor controller detects a higher current draw it stops. This happens when the mechanism reaches the travel limit and stops moving creating resistance to the motor turning and the motor daws a higher current to continue pushing. the motor controller senses this and stops the motor. Check to see that nothing is hampering the travel of the rails creating resistance. The third method is to program the motor controller for a specific time or motor turns to stop the mechanism travel at preset levels. This can be found in the installation manual.
Hope this helps.
Dec 13, 2014 | Televison & Video
Garage door opener
Does the travel direction make a difference? There is typically upward / downward force adjustments. Also when it stops will it start again immediately if you activate it.
Mar 31, 2017 | Building Materials
Flashing blue light
1. turn it off2. hold centre button until blinking blue and red3. briefly press volume down4. turn it off= fixed :)
From Sennheiser UK:http://www.sennheiser.co.uk/uk/home_en.nsf/root/contact_menu_technical-question_telephone_headsets_faqs_mm400_series_bluelight
Jun 19, 2012 | Sennheiser MM 550 Wireless Headphones
On operating my remote the garage door opens but when l try to shut the door it shuts then opens straight away the only way l can stop it is to press the remote again .There is a green light that keeps...
It sounds like the door is traveling too far, hitting the floor and then reversing to the open position. If this is the case you need to locate the 'down limit' control on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary to get it just right.
It is normal for that small green light to flash randomly. It can also assist in diagnosing some problems by flashing a code. It will flash a number of times and then pause and then repeat. If this is the case, post the number of flashes.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3hp garage door opener
When i try opening the garage door from the wall button the door only opens 3 inches or so, then stop but makes several loud clicking noises. I've played around with the travel limits as well as the open force switch but the same thing keeps happening. Any suggestions?
Jun 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Craftsman 1/2HP Door Opener won't stay closed
Loosen the chain and run the opener until the sprocket runs in the counter clockwise direction and stops. Now with the door in the open position replace the chain. This will get everything back into sync but I hope you remembered where all those controls were. You need to put them back in their original positions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP Starts AND Stops Going Up or Down
with the age of the door, chances are it just doesn't move as easily as it once did causing the built in limiters to stop the door. the limiters are designed to stop the door from crushing something or someone if the safety beams fail and there is an obstruction in the path of the door. Some units allow you to raise (increase) the force used to move the door. Most times the adjustment screws are hidden either behind the light lens or behind a removable panel. The limiter screws are NOT the screws used to adjust the travel of the door. If you don't have the manual for the opener, you may be able to download one to assist in locating the correct screws if the opener has this adjustment. As far as by-passing the safety beams, just place a jumper wire in place of the safety beam receiver.
Please take the time to rate this solution.
Thanks for using Fix Ya.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
106 people viewed this question
Top Chamberlain Car Audio & Video Experts
Iron
Iron
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
