Question about Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB
Amana side-by-side refrigerator/freezer
My Amamna side by side refrigerator door opens when you close the freezer door, any suggestions? I have cleaned the seals, they seem to be fine.
  • 126 Answers
Raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Posted on Jun 26, 2009
Freezer freezes but refridegator is warm on amana french door refrigerator.
it could be a defective damper vent door,( frozen shut from condensation) between the freezer and refrigerator,the motor that opens and closes this door,or a thermistor in the refrigerator that signals the control board in the rear of the unit to operate the damper vent door motor to open and close this door
Jul 28, 2010 | Amana AFD2535DES French Door Refrigerator
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    Freezer door opens when you shut the refrigerator door
    Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
    Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
    An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
    Sep 03, 2009 | Amana Refrigerators
    Freezer door pops open when fridge door is closed.
    well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
    May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
    Freezer door wont seal and stay closed
    Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
    Hope this helped.Let me know by rating me or
    for more help go to live chat.Thanks
    Len West
    Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
    Amana 22 side-by-side refrigerator, freezer door opens slightly
    There are three possibilities to this problem:
    1. Door seal which should be magnetic is faulty.
    2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
    3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
    Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
    Refrigerator compartment not cooling
    If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
    Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
    Freezer door misalignment on ARB8057CSL
    Before adjusting hinges you need to take a good look across the door from the side to make sure the door is not warped rather than the hinge misaligned. Cannot give much info on hinges but most do not give much adjustment and most can be accessed it is possible that one of the fixings is loose. The other possibility is that the seal is preventing the door from closing, although it does sound as though it is the top hinge not pulled towards the cabinet properly. Sorry to be vague. Hope this is of some help.
    Sep 11, 2007 | Amana ARB8057CSL Bottom Freezer...
    Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
    175 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
