Question about Magic Chef 31100 Gas Kitchen Range
Annoying beep Where the time is displayed, i keep getting the numbers -F1- along with a very annoying beep. How do i turn it off. Please help.
  • guylaineduga Nov 03, 2008
    Same problem here...
  • 28 Answers
On models where the keypad and electronic control are one integral part which can not be separated, an F1 error can be caused by a problem in the oven temperature sensor or its wiring circuit. If not it's the keypad.
Posted on Dec 10, 2008
Makes beeping sound
A bleeping sound that keeps on going is usually a faulty key on the keyboard. Does a menu asking which OS you want appear just before boot up? If it does, my money is on the Esc key.
Jan 31, 2014 | Lenovo G570
Model JBGP80 MEV2BC Display panel shows "F1" and emits beeps (very annoying)... while unit seems now to be working fine otherwise. I will check and re-establish any cabling, etc. Meanwhile, how do I...
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 16, 2010 | GE JGBP80 Gas Kitchen Range
My oven has been beeping for the last couple of hours. My son pushed bake and put the temp up to 425. After it preheated, it started beeping and F1 is showing on the display. I have tried everything to...
you can first try to reset the curcuit breaker
flip on and off
if this does not help
usually an f1 error is your control board
what is your full model number from inside the oven?
Apr 22, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
How can I turn off the beep sound on my exxcel
I've just found my instruction manual and managed to turn the volume off on mine after 6 months of annoying beeping.
You turn the programme selector to off then turn it one programme to the right, press the rpm button and keep it pressed while turning one more programme to the right, release them both and a number should be displayed on screen I think volume 2 is the default one. You then click the "ready in" button until desired volume is reached. You have a chioce of zero through to four. After volume is set turn programme selector to off position. The annoying beep should be no more!! Hope this helps others.
Feb 15, 2010 | Bosch Washing Machines
F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
IT BEEPS F1
We repair many no longer avaiable control boards like yours. If a technician says your oven needs to be replaced because of obsolete electronics, this is not true. Go to fixyourboard.com to get quote.
Aug 28, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Jun 09, 2009 | Samsung Cell Phones
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
F1 Displayed
Carol, The F1 error code could be cause a failed ERC(EOC,Clock assembly)or a faulty touch-pad. To check the ERC and the touch pad, follow the steps below : -Disconnect renger's power cable. - Gain access to ECR's back. - Disconnect the ribbon cable between the ERC and the touch-pad - Reconnect renger's power cable and switch on. - If you will get the F1 and the beep,it means that the ERC is fault and should be replaced. - If you don't see the F1 code and don't have the beep, you should replce the touch-pad. Good luck !
Jun 13, 2006 | Kenmore 92329 Electric Kitchen Range
Magic Chef 31100 Gas Kitchen Range Logo
156 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
