Question about Samsung SCX-4216F All-In-One Laser Printer
Problem printing after replacing toner cartridge
Replaced the toner cartridge with a factory replacement we have also tried 2 additional cartridge all with the same results. The printer will not print a full page in either the pc print mode or copying mode. it only prints about 1" on right side. The rest of the sheet is blank. We have replaced the cartridge before and had no problem.
We replaced the cartridge and it is still copying in bad quality.
Printing is fine but it is the copying that is the problem.
Posted on Sep 09, 2008
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    My brother mfc-7220 printer show"toner
    You do not necessarily need to replace the toner right away. The toner has 2 visible clear tabs when you are looking at either side of the toner cartridge. This is for a reader built into the unit to recognize that the toner is low. However, if you cover those clear plastic pieces with black electrical tape, you will be able to achieve an additional couple hundred prints and when the toner no longer prints on the page, you are definitely out of toner.
    Sep 21, 2011 | Brother MFC-7220 All-In-One Laser Printer
    Hello! My Samsung ML 2010 Laser Print has started to print pages with streaks of ink across them. This makes the pages more difficult to read, and certainly cannot be used for formal letters. It also...
    there must be waste toner in your toner cartridge
    the waste toner box is fitted above the drum in toner cartridge with 2 no screw open it and empty then try to print
    Jan 26, 2011 | Samsung ML 2010 Laser Printer
    Dell 1710 printer. When printing just tthe top 2
    Have you tried replacing the drum? That is the part that the toner cartridge actually sits in.
    Jan 28, 2010 | Dell 1710n Laser Printer
    Everything prints on left half of page
    First, are you using a factory Xerox cartridge and Xerox toner?
    As to the document, are you getting the entire document printed or is the document simply cut off as if the printer cartridge is out of position?
    Oct 19, 2009 | Xerox Phaser 6180N Laser Printer
    Toshiba E-Studio 202L cartridge does not match manufacture
    Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
    Jun 23, 2009 | Toshiba e-Studio 202L Copier
    Prints completely black page when copying.
    hello! are you usinga brother oen toner and drum cartrdige? that is the first thing to try, you are welcome to post back to me for additional help good luck brother tech
    Jan 22, 2009 | Brother IntelliFax-2820 Laser Fax
    Toner Low Light on within 2 months of replaced toner cartridge
    Yields for cartridges are based on a page being only 6% covered. Most letters are about 10% coverage. If you print anything with lots of print (especially bold) your yield will reduce drastically. The same thing goes for pictures.
    Nov 25, 2008 | Dell P1500 Laser Printer
    Konica minolta error
    I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
    Hope this fixes your as well.
    Chris
    Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
    Samsung SCX-4216F All-In-One Laser Printer Logo
    236 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
