Question about Pioneer CD Receiver - DEH-P470MP - CD/MP3 Player 2005 Model
RCA jacks not working DEH-P470MP
I recently installed a pioneer DEH-P470MP. It works great. I ran all wire to hook up my amp. Everything is new. I pluuged the RCA's into the radio and the amp. There is nothing coming out of my subs. I tore everything down and reinstalled with a new kit and still nothing. Could it be that my amp does not have a proper ground? Any other suggestions would be greatly appriciated.
  • Daniel Thurau
    Daniel Thurau Aug 07, 2008
    The Amp lights up. I just re did the ground. I filed the paint away in my spare tire whell well. I drilled a hole and put a nut and bolt in. Still no go. I have done many installs and have never come accross this.
  • 53 Answers
Does the amp turn on when the deck is turned on ? is the ground hooked to the body of the car to bare metal w/out paint ect ...under it ? you may want to take it to a installer there are many things it could be they can also test your rca outputs if thats the problem. curcuit city is a cheap place to have your equipment tested if you live close to one
Posted on Aug 07, 2008
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Will a amp work with this deck
you can get a amp to work on any deck although u may have to rig it a little bit all u need is sound coming from the stereo and if u will take the rca one end and cut it and strip it u have a wire inside each one and then u have ground wires surrounding the inside wire twirl them up like 1 wire and then strip back the inside wire hook that one to front left pos wire and hook ground wire to front laft neg and do the other rca wire the same just hook it uo to front right or if it has rca jacks on the back of the stereo just hook ur rca wires into them and to the amp
Feb 24, 2010 | Pioneer DEH-1600 CD Player
I NEED WIRING DIAGRAM FOR PIONEER DEH-P470MP
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4700MP/index.html
the wiring diagram is on page 5 of the installation manual
Cheers!
Oct 11, 2009 | Pioneer DEH-4700MP CD Player
Pioneer indash stereo/cd player DEH-7500MP,no internal amp output
some cars have internal amps for the speakers try connecting the remote wire it's the blue wire with a little white on it worked in my moms van.. if that does not work try testing it with a speaker from your house
Mar 31, 2009 | Pioneer DEH-P7500MP CD Player
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
Trying to hook up mp3 player
they are out jacks and you need to run the rcas to an amp and then run your speakers off the amp your mp3 player should work when you plug it in the front and press source aux unless the front jack is an out only
May 25, 2008 | Pioneer DEH-P400 CD Changer
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Subwoofer instalation
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
Aug 20, 2007 | JVC Arsenal KD-AR560 CD Player
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
156 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
