Question about HP Photosmart M307 Digital Camera
Flash not working
Can I get my flash repaired or get a replacement bulb? Thank you.
  • Dennis Smoot
    Dennis Smoot Mar 07, 2009
    Arua,
    Thank you for the response. Since my post I bought a damaged camera of the same type on eBay. I swapped out the flash board and flash. It now works perfect.
    You must be very careful handling the board. The flash capacitor carries quite a punch and will give you a good shock! Thank you again.
    Scholar:
  • 54 Answers
Yes it can be repaired. I it is quite easy of a repair. I have done it before. What I have done is swapped the flash board with one from another camera with a different ailment. I can give you instructions on how to do it.
Posted on Mar 06, 2009
How do you replace the flash bulb in sony cyber-shot dsc h10 camera?
You must send the camera in for repair to replace the flashing unit
Jan 23, 2012 | Sony Cyber-shot DSC-H10/B Digital Camera
Flash does not fire consistently
Have you tried replacing the bulb at all or check to see if it may be loose or not have a good connection which may cause it to work sometimes but not all of the time
Jun 29, 2008 | Metz Mecablitz 60CT4 TTL Flash
I HAVE 1999 BMW 323I AND THE PASSNGER SIDE HEADLIGHT WAS FLASHING EVER FEW MINUTES UNTIL IT STOP WORKING AND NOW THE DRIVER SIDE IS FLASHING EVER FEW MINUTES
it's only a bad bulb,they do that sometimes,i always replace both headlight bulbs when one goes bad.because they often follow each other,when one goes,the other not too far behind it.the elements in the bulb itself are making contact and then not making contact is the reason behind the flashing.replace both headlight bulbs and you're problem will go away. thank you for choosing fixya.com
Jan 10, 2011 | 1999 BMW 323 Series
My S730 camera flash will not work it will take pictures without a flash though. Can the flash bulb be replaced or is it cheaper to just get a new one?
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 28, 2009 | Samsung Digimax S730 Digital Camera
The flash made a pop noise like the bulb failed. The camera works, but no flash. Are parts available or who can repair the camera? Thank you.
Hi Dear,
Yes your are correct in saying that the flash made a pop noise like a bulb failed.
The flash of a camera also consist of a bulb which when triggered give live for a very short span of time.
In your case as observed from your sayings, the flash bulb have failed. It is not a big issue.
As a camera is a delicate object. I would suggest you to take your camera to the authorized service station only and get the bulb replaced by the expert hands only.
Hope this will work out for you. If there are any more queries in this regard we would love to hear form you. We will be obliged to solve your issue.
Have a nice day.
Nov 11, 2009 | HP R967 Digital Camera
2006 pt cruiser on drivers side rear turn signal
The turn signals flash depends on each and every bulb working correctly. When one bulb fails, you will notice a change in the flash frequency, as you describe.
Replace or repair the bulb that is not working, and you should be good to go.
Doc
Sep 14, 2009 | 2006 Chrysler PT Cruiser
FLASH LIGHT BULB of my DSC H1 digital camera HAS BLOWN
You need to replace flash bulb board of DSC-H1 as shown in below image. (item # 304) Part number is as follows..
A1119331A ST-124 BOARD, COMPLETE
It is available in Part Store.
Replacement of ST-14 board (flash bulb board) requires expertise and solder work.
Thanks.
Jul 28, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
TV won't turn on - just replaced lamp
I had this same problem. This (panasonic) set is sensitive to the type of bulb used. Don't use a remanufactured one, get a philips/osram or an OEM. If that is what you have, move on to the ballast. Replacing the ballast isn't easy, if you are electronically inclined, you can remove the back panel and the page size aluminum brace, it has two large square cut outs. The shiny silver box under that brace ( maybe 10" x 4") is the ballast. That is typically the next thing that goes out. The bad news is the cheapest I have ever been able to find a replacement was around $350. But again, if you have soldering skills, order a ballast repair kit from ebay ($30) and go to work. If you decide to do that, let me know and I'll email you photos and walk you through it. Once the ballast has been repaired, if it still has the problem, The power supply is bad. At that point take the bulb back out and sell it on ebay or send it back and use a LFH (large F****** hammer) and take out your aggression. Its not worth fixing. The powersupply board is more than the TV is worth. Most of the time this problem is fixed with the ballast. But its a CHORE to get to it and remove it to work on it. I'd be happy to help and I can send vids and pictures, depending on what you'd like to do.
Good Luck.
Jan 11, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Flash: PCB Replacement v. New Bulb!?
I had the same issue. The flash is set to go off, the camera assumes it went off, (as the record metadata shows) but it doen't go off at all, and the piture is underexposed.
I bought the 100 page repair manual, which is ONLY a dissassemble/reassemble manual with NO diagnostics. (Got it on ebay) So I was atleast able to get to the capacitor and flash bulb. I saw 300V across the capacitor leads, and the same 300Volts across the flash bulb leads. SO I am assuming that there is a transistor or relay that drops to ground to fire the flash that isn't working, or the electronic signal to drive that isn't working.
It seems most people replace the entire flash circuit board(which is near the capacitor under the left hand side). But it seems Nikon only sells parts to it certified repair facilities.
Ugh.... Looks like I'm buying a SB-600, as this is the cheepest solution. Too bad, because the on-board flash is more than decent. I hope the SB-600 thrills me enough to change my mood. :)
Oct 07, 2007 | Nikon D50 Digital Camera
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
HP Photosmart M307 Digital Camera Logo
83 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
