Question about Maytag Ovens
Maytag Oven- the oven ignitor glows but does not always light.
The oven ignitor glows but does not always light. Sometimes it does, sometimes not. When it glows I do not hear the gas being released. Is it a bad ignitor or release valve?
  • 4 Answers
SOURCE: Oven will not ignite
The problem is not fixed, but I know it involves replacing the ignitor and/or the gas valve. I just wanted help diagnosing the two so I only had to buy one part if I could. We live on a budget and if I could avoid replacing an unnecessary part that would help. I am afraid your elite people would just tell me to start with the ignitor and then the valve.
Thank you just the same.
Randy
Posted on Jan 03, 2009
jtbjtb
  • 135 Answers
SOURCE: oven stopped working
No, that is a top burner valve. Most likely the igniter is bad, part # 12400035. The only way to test it is with an ammeter; it must draw a minimum of 3.3 amps to cause the valve to open. Oven valve part # 7501P133-60. These go bad as well, but not nearly as often. If you are going to take a risk, try the igniter first. Available for $40 at www.timerking.com and elsewhere. Hope this helps!
Posted on Jan 28, 2009
  • 2187 Answers
SOURCE: Gas oven igniter glows, but oven does not turn on.
That is correct. You will have to check if the valve needs replacement or if there is power being sent to the solenoid for the valve. There must be just a connection problem.
Posted on Aug 17, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Acu Bake oven, burners light, broiler
You just need a new gas valve. This is a simple repair for you and you can save a lot of money by repairing it yourself.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number and we will get the correct part out to you right away.
We look forward to getting you cooking again soon.
Posted on Nov 08, 2009
  • 494 Answers
SOURCE: Replaced bad thermostat on Magic Chef model
Gas shut off valve handles are perpendicular to the gasline when closed and parallel when opened. If you are referring to the appliance regulator behind the stove, the lever should face up or out, as opposed to sideways. This particular lever only shuts gas down to the oven and not the stovetop.
Let us know if you need more assistance.
Posted on May 16, 2010
I have a Maytag (Magic Chef) gas oven model CGR3730ADH. The oven will not heat up. The ignitor will glow/heat up but there does not appear to be any gas flow. The top burners work normally. After...
HI,
First of all, thank you for all your information. A rule I live by, even if an ignitor glows does not mean it works. The ignitor works on the flow of electricity through it not how bright it glows. If you can use a amperage meter, hook on one of the two wire to the ignitor directly. You need 3.2 to 3.6 amps to open the safety valve. If lower than 2.6 amps, it will not allow gas to enter the burner. If you have no clue what I am asking you to do, you can purchase and replace the ignitor and life will be better. P# 12400035. Its not difficult to change, the screws holding the ignitor in place sometimes strip out, when you get them off, you can replace them if needed.
Good Luck
Jul 23, 2011 | Maytag Ovens
It looks as though the pilot for our Maytag oven is out. The burners are working fine. Could it be the thermocoupler, and if so, how do I identify it?
It is rather unusual for an oven these days to have a standing pilot, (and thus the Thermo Couple)
Are you sure yours doesn't have a glowing ignitor to light the gas?
Usually there is a separate ignitor and burner for broil, and a separate one for the Main oven burner-
Can you see the ignitor glow on one or the other burners?
If the ignitor is broken-- you can not get the burner to light
Do yo want to try changing the ignitor?
Let us know more about what you have--
Mack B
Jan 23, 2011 | Maytag CWG3100A Gas Single Oven
I have a frigidaire fgf337awa oven. The burners always work, but my oven/broiler only works sometimes.
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 14, 2010 | Ovens
Older Maytag built in oven. starts and reaches desired temp, sometimes. Other times it never lites. electric igniter always reaches a glow
Even if the igniter glows... that doesn"t mean the ignitor is good. The igniter is wired in series with the oven bi-metal valve. Many times the ignitor will not allow the correct current to the oven valve for it to open... even though it is glowing. I would recommend replacing the ignitor first, you should be able to find one for under 40 dollars.
Aug 10, 2010 | Maytag Ovens
When you turn on the oven the egniter glows, but it may take several minutes for the thing to light. sometimes you smell gas and sometimes not.
This is usually a sign that the ignitor is wearing out. Even though it glows, it is pulling just barely enough current to cause the gas valve to open. A new ignitor should take care of the problem.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Fridgedaire Oven burner sometimes doesn't light
heatman101
dddddddd76
May 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven lights sometimes and sometimes it doesnt
Replace the glow bar ignitor. It is weak.
Aug 27, 2009 | Maytag Ovens
Oven will not light, hot surface ignitor is working, is this a safety valve problem?
While the ignitor is glowing, tap on the valve with the handle of a large screwdriver. If the valve opens and the burner lights- replace the ignitor. If not replace the valve-depending on age I will sometimes do both right then.
Eric
Jun 25, 2009 | Ovens
Wall oven will not light
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
Mar 28, 2009 | Maytag 24" Built-In Single Electric Wall...
Ovens Logo
70 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
