Question about Electrolux Lux 5500 Canister Vacuum
Electrolux Canister - Renaissance model
Change bag light stays on after changing bag
    Novelist:
  • 97 Answers
Probably a clog, because the change bag light is nothing but an airflow sensor.
Check your hoses to ensure that there are no blockages, and also check inside the powerhead behind the brushroll.
-R
Posted on Aug 07, 2008
2 Suggested Answers
SOURCE:
defrankond
  • 66 Answers
SOURCE: Electrolux Renaissance canister
there are a couple situations to this issue. one is the bag that was replaced is a incorrect one and it is not meeting the switch for the bag pop circuit. some over the counter bags cause this issue. another problem could be the switch itself. or the bag door not being tight enoug to make contact with the bag.
Posted on Nov 29, 2008
How to fix sensor s12. red light for bag stays on even when vacuum bag is not full and the vacuum is clear
You most likely will need to change the Yoke assembly. There is a sensor built in that gets clogged with fine debris over time. This will take care of the problem.
Feb 09, 2015 | Windsor SR12 Sensor Bagged Upright Vacuum
Bag light wont turn off
Hi there! The vacuum may be still sensing dirt in the cleaner. Try wiping the area down in and around the bag port. Be sure you are replacing the bag with a genuine Hoover Type Q bag. Also, when assembling the bag remember to slide the red bag door lock to the right to lock it on. If the check bag indicator light still comes on there may be an issue with the sensor on the vacuum. We would recommend taking your vacuum in to a Hoover authorized service center for repair. Hope this helps! Service Center Locator
Sep 13, 2014 | Hoover Platinum Collection Upright Vacuum
The vacuum won't turn on. plugged in, all lights flashing. no power
When switched on the vacuum goes through a self diagnosis test. Lights will come on for a while, then go out. If everything is okay, then the blue "Optimum" light will come on and stay on. If it turns of, a red indicator light should come on providing information on what's needed; i.e., filter or bag change needed.
Aug 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Bag change indicater staying on and vacuum smells hot when using
I suspect there is a blockage somewhere along the pipes leading to the dust bag.
The bag full or bag change indicator measures how strong a vacuum is present at or near to the point where the bag is connected to the pipes. Under normal conditions an empty bag poses little resistance to the air passing through and therefore causes only a slight vacuum. A full bag poses a lot of resistance and therefore causes a strong vacuum which in turn makes the indicator show time to change.
If, however, there is a blockage somewhere, regardless of the state of the bag, a strong vacuum develops which causes the indicator to show as if the bag is full.
The hot smell is proably a result of the motor having to work hard trying to overcome the blockage.
Try to look into all the pipes - you may need to do a bit of dismantling and/or strech out flexible pipes to do so - to see if there's anything stuck. Also try some (careful and gentle !) poking through the pipes with something like an un-ravelled wire coat hanger, but take great care when poking through the flexible pipes as these can be ripped and then you'll have a differnt problem !
Sep 16, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Bag full indication comes on; changed bag; still wont run.
Turn the knob on the top of the vacuum all the way to the right and try it again
Jun 15, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux upright bag light stays on even when bag is not full
Once you change the bag, be sure to turn the machine off and back on to clear the fault. If it is the full bag light that is on, and not the "?" light, and you have a new bag in place, then you probably have a bad control valve. I would suggest finding the closest Aerus (formerly Electrolux) dealer and having them change it. It shouldn't be too expensive. If you have the "?" light illuminated, the bag probably isn't pressing the actuator like it should. When placing the new bag into the machine, be sure the bag top presses the small button in the lower right hand corner. Good Luck!
Jan 02, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum will not stay on, new bag in place and power to machine.
It sounds like you have a bad control valve. Take it to you nearest Aerus (formerly Electrolux) dealer and have them change it for you. It shouldn't be too expensive. Good Luck!!
Aug 07, 2008 | Electrolux Lux 5500 Canister Vacuum
Electrolux Lux 5500 Canister Vacuum Logo
703 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
