Question about Bosch Washing Machines
My bosch washing machine wfo2865 exxcel is not spinning. Every thing else works. The engineer said it could be the brushes. How do I take the motor out to replace the brushes
    President:
  • 1,462 Answers
Remove back panel.remove motor wiring undo two bolts in front. remove belt. motor will pull out.
my experience of these is that often the commutator is damaged hence brushes worn
Posted on Aug 07, 2008
My bosch washing machine does not spin. I have just fitted new brushes. I fitted new brushes thinking this would solve the spinning problem. The machine just starts its washing cycle and then when it is...
Check the pump , first make sure it's not got water in the drum if so drain ,undo drain pump cap and make sure nothing is blocking the pump shaft as this will stop it from spinning
Dec 19, 2017 | Bosch Exxcel WFO 2864 Front Load Washer
Bosch exxcel machine doesn't appear to spin
Possibly the filter needs cleaning, this is located at the bottom front right of washer behind drop down flap or cover.
Unscrew anti-clockwise to remove and clean
If it still will not spin, then the brushes in the motor probably need to be replaced.
Mar 08, 2010 | Bosch Washing Machines
Bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
My bosch exxcel express washing machine spin has stopped working any ideas.
not turrning drum could be motor brushes not filling could be door interlock switch..not coming on could be plug fuse or off/on switch...
Oct 24, 2009 | Bosch Logixx WFR 3267 Front Load Washer
Bosch Exxcel 1200 Express Washing Machine spin not working
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
Nov 09, 2008 | Bosch Washing Machines
My Bosch washing machine drum does not spin at all
No, there is no rotation on the drum at all tresilla.
Jun 21, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
My bosch exxcel 1400 washing machine will not spin when on cycle what is this fault
After checking that the pump was working freely and water was being extracted by means of the pump, I then assumed it could be one of two faults faulty brushs or motor but still as washing machines can hold a charge of electricity capable of causing a fatality after being isolated I ordered the parts required by refering to the model no. and enr no. located behind the door and requested a competent person to fit them. The parts i ordered were brushes.
Jun 15, 2008 | Bosch Washing Machines
Washing Machines Logo
365 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
