Question about Dryers
Help my tumble dryer wont heat up we think its the thermostat but trying to find one to fit our hotpoint aquarius ctd 40 is a night mare
    President:
  • 1,462 Answers
Stats come as a kit and often go faulty. if you are in uk, try currys masterpart
Posted on Aug 07, 2008
Hotpoint Aquarius tvm560 tumble dryer is blowing cold Air can it be fixed
sure it can., check ur heating element, with multimeter, and check ur thermostats the hi-lo the thermal cut off , cycling thermostat, etc.
Jan 28, 2015 | Hotpoint Dryers
I have a vented TL61P Hotpoint Aquarius tumble dryer which will not heat with or without the no heat button pressed !Could this be a thermostat problem or the heater ?
check thermostats as above posts have commented check also condition of elements as my dryer elements are cracked and need replacing just had a new belt fitted so reluctant to let it go
Mar 19, 2011 | Dryers
Not heating up
first thing to check is the heating coils,,if ok go to the censor just over the top of the door,,,this is most likely the dud part
Jul 10, 2010 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
Hotpoint aquarius tdc32s not heating up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Sep 03, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint ctd 40 wont heat up
Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jan 27, 2009 | Hotpoint Dryers
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Jan 23, 2009 | Dryers
I don't have any heat from my hotpoint aquarius ctd40G Tumble Dryer. I have cleared all the fluff from the condenser unit and unplugged the mains and tryed it all again but we still do not have any heat...
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Dryers Logo
99 people viewed this question
Top Dryers Experts
