Question about Samsung HCL4715W 47" Rear Projection Television
Where do I get a new lamp, and how do I put it in?
The screen flashed and went blank. I assume it was the bulb burning out.
Is this an easy fix?
  • kaalucat Oct 04, 2008
    I have model# hln5065wx, black screen - but intermittent buzzing sounds
    (think weedeater). Do I need a new lamp?
    Kemper
  • Samsung Master
  • 8,617 Answers
Is your model a HCL4715? If so it doesnt have a lamp it has three CRTs ( picture Tubes) instead. Please respond to this same post and verify your model number and tell me what happens when you press the power button, and I will assist you with your problem.
Posted on Aug 08, 2008
Hitachi 50v500a: Lamp blew, oredered a replacement. Just installed it, and I still get the "lamp" light on and it wont power up.
Remove lamp and look to see the socket the lamp plugs into did not get bent out of position---just check to see if it went in right and after that you put the door back(set will of course not operate if door or cover removed).
If we assume New lamp good and installed correctly the next possible issue is the Ballast which powers the lamp--Not easy on this set to check voltages---should have a plug with over 200-300 volts from power supply going to--the two wire plug from the lamp goes directly to it.
Apr 04, 2012 | Hitachi Televison & Video
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
Red bulb lamp flashing and screen won't turn on. Just replaced lamp bulb with new one - didn;t fix it.
Please make sure lamp cover is fixed in its place securely, you know it was removed to replace lamp so put lamp cover back in its position and turn ON tv.
Hope this info will help you.
Feb 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Lamp went out, ordered new bulb and put in but TV did not come back on but the bulb light keeps flashing light orange. Sent new bulb back just in case it was faulty & ordered another 1. I just received...
Make sure lamp cover is put back in its position properly after bulb replacement.
If I have info about model and brand of your TV then I might offer better help to fix it.
Jan 15, 2010 | Televison & Video
My 2005 Dodge Diesel flashed Lampout on the way home this evening. Got home Checked all lamps were good. So i thought mabe it may flash a code, when i tried it flashed DonE then went out? Please help
Hi I'm litoshop, if the lamp out flashed then you have a light bulb that burned out check all the bulbs head light, parking lights, brake lights and signal lights, tail light, plate lights must likely one of those bulbs burn out good luck. if this information has been useful please let us know thank you.
Aug 04, 2009 | 2005 Dodge Ram
New bulb not working
ITS NOT A BULB ISSUE IT IS A TRANSISTOR THAT MEASURES HEAT TO TELL THE FAN WHAT TEMP. TO KEEP THE SYSTEM AT AND IT IS BURNED OUT AND YOU WILL HAVE TO TAKE IT TO A DEALER AND SEE IF IT IS WORTH FIXING.
Feb 25, 2009 | Optoma EzPro 738 Multimedia Projector
No picture, just sound
You need to replace your projection light bulb - the part can run from $100-350 depending on how you shop around, I would suggest ebay- as this was the cheapest route for me.
Feb 03, 2009 | Televison & Video
Samsung HCL4715W 47" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
