Question about GoVideo Televison & Video
I need to be able to change from one movie to the next. In other how do I change the movies horizontally on the machine itself
I did not fix the problem as of yet. I must tell you of ny outrage at you trying to get money from me for a product I purchased from you corporation.
thank you big business
Posted on Aug 08, 2008
Auto restart
Your machine is rebooting itself while you watch a movie on it? Could be a couple of things. First, is this a laptop or desktop? When is the last time you updated your video drivers? If this is a laptop, does it get very hot just before rebooting?
Theories work like so:
1. older video drivers can be causing a cpu panic condition due to a bug. This is more common with PC games vs. watching movies, but still possible. Updating your video drivers may help fix the problem if that's the cause.
2. heat: if the computer overheats, it will reboot to protect itself. As for why it's getting hot--could be that your video hardware or cpu is getting too hot playing the movie. Could be that your cooling fans are bad. This is why I asked about the machine getting hot.
Another possibility is the need to update either your BIOS or hardware drivers.
Please post more info if you require additional help.
Oct 18, 2013 | Intel Computers & Internet
Horizontal lines in photos
two issues..
lens is dirty..
or the memory or disk is needing a reformat.
you say that the movie making mode is clean?
Mar 17, 2008 | Sony Cybershot S650 Digital Camera
Horizontal lines appear on 32" in some hd format movies.
The technician is right, the TV will not show such lines selectively. Try changing the input device to some other. Play some sure shot, genuine DVD.
Jul 19, 2012 | Televison & Video
How do I download movies on an ipad2? Is there a way to download a movie that I'm watching on my ipad to the machine itself? It's a WIFI machine and I'd like to be able to view it offline.
There may be an app for that but haven't found it yet.Use a free software program like freemake video converter to convert movie to correct format then add to itunes list to send to ipad.Very easy to use program with lots of converting options.You can also convert straight from non copyrigted dvds you already own.They also make a video downloader for youtube and other sites.Get it at freemake.com.
Oct 12, 2011 | Apple iPad 2 Wifi 16GB
Need to rotate several Flip videos
When you watch a movie in a theater, have you noticed that the entire movie is in horizontal position? That's because you can't rotate videos.
Apr 05, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
How to insert video in the PowerPoint 2003?
Insert a movie and play it automatically
In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
  • On the Insert menu, point to Movies and Sounds, and then click Movie from File.
  • Click the video you want to use and then click OK.
  • Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
  • After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
    I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
  • You should now have a small rectangle sitting on your slide.
  • Insert a movie using a file on your computer or in another location, such as a server.
  • The movie appears as a still frame on your slide.
  • The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
    Play the movie full screen
  • Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
  • The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
  • If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie
If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it.
3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear.
You have added an On Click effect. The animation effect you added is the one with the Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this:
6. You are done. Test this to make sure it works by starting the slide show.
(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce: How to insert a Movie (or video) into PowerPoint 2003?
Jul 06, 2010 | Microsoft Office Professional 2007 Full...
Sanyo digital camera model- vpc5500
Playing Back Movie Clips
You can play back the recorded movie clips on the LCD monitor screen. However, the
sound recorded with movie clips can only be played back on a computer.
1. Press the button.
2. Use the four-way controller (����) to go
through the images until the movie clip you
want to play back is displayed.
�� To view the previous image, press the
four-way controller (��).
�� To view the next image, press the
3. Press the button to start playing back
the movie clips.
�� To pause or resume movie playback, press the button again.
Dec 25, 2007 | Cameras
Trouble downloading movies from digital camera
I am a big movie fan who need to search and download a lot of movies to satisfied my movie thirsty.Fortunately, I did get what i want.
watch and free download full length movie/ mp4 format movie, iPod format movie,
you can go to here :
http://free-download-films.com/
you can download any other movie you'll EVER want to see. Regardless of whether that movie comes out next year or it came out last year or even 10 years ago. As soon as a movie is available for download you're able to access it.
Dec 09, 2007 | Canon PowerShot A570 IS Digital Camera
Televison & Video Logo
29 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
