Question about Olympia InfoGlobe Cordless Phone ol3020
Phone is not working
My telephone is not working even though I charge it for long time.  The info or letter show on the screen is not clear.  Is it the battery problem or my phone is broken?  Please help
It is not worth to fix it.  I just got a new one.  Thanks!
Posted on Aug 08, 2008
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
Battery on G-zone Commando Losing charge even though it shows it is charging
A charger can indicate it is working but if it is trying to charge a dead battery you will get the result you describe.
Mar 09, 2014 | Casio G-zone Commando
IPhone 3GS battery replaced, connected to itunes via USB cable and synced, battery percentage indicator showed a power plug didn't start charging. Charger removed and over night the battery seemed to have...
Is the replacement battery an original equipment battery? I bought an aftermarket battery for my Samsung and the phone will not recognize the battery even though the specs are identical. Nice trick by Samsung. See if I ever buy another product of theirs again. Anyhow try putting the old battery back in and see if it will function while plugged in. Otherwise head to the phone store.
Nov 01, 2013 | Cell Phones
Hello, I have the panasonic GD55 and have not used it for quite some time. I charged the battery, put it on the phone and when I turned the phone on the screen is hard to read and not clear, I am able to...
Hi I would suggest clearing the phone to factory reset and fully charging it as though it is new. THEN start using it again. I would uplink to your computer and backup any info you don't want to lose. An alternate could be to check with the seller of your phone. Since you have not used it for awhile, the complete recharge may be needed. Also please check to ensure that in some time in the past the phone was not dropped or wet. Sometimes the screen vue is compromised by these things.
Jul 04, 2011 | Panasonic GD55
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
ENV (gen 1) blue screen and won't hold charge
i think you should talk to verizon about getting a new one. you really have to keep annoying them eventualy you should get your new phone!
Nov 15, 2008 | LG enV VX9900 Cellular Phone
Bad battery or bad phone?
Looks like your phone is in 'Bootloader' mode, that's why it shows your bootloader info. Take your battery off for about 5-10 mins, and restart your phone.
Jun 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola razr v3m battery problems and bootloader ini showing on screen
Well it is both. It should only ever say bootloader when it is plugged in to a PST machine and getting the software updated. I would say that it the hardware is causing the poor battery life or a combo of the battery and the phone.
Apr 24, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Does not charge properly
If battery is blinking but not moving forward then replace ur battery.regarding the stick plz contact hardware vendor.
Oct 15, 2007 | Sony Ericsson K700
Olympia InfoGlobe Cordless Phone ol3020 Logo
108 people viewed this question
Top Olympia Lands Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
