Question about Sky Hawk Computers (PSR5601W-SL) ATX Mid-Tower Case
Front headphone and microphone jack don't work.
I attached headphones to the jack in the front/bottom of the Sky Hawk Computers ATX Mid-Tower Case and nothing comes out. Is there a setting in the BIOS, jumper to set, or software I can use to enable this feature.
XP SP2
    Guru:
  • 147 Answers
Based on what you've submitted, I'm listing a number of solutions which may or may not help. Try the following:
1.) Double-check the color coding on the jack to the port and ensure they match.
2.) Go to Start Menu>>Control Panel>>Sounds and Audio Devices. If it says you have "No Audio Device", then we have a problem.
If it says you have an audio device, tinker with the tabs and settings until your sound output is good.
Please let me know if this helps. If you need further troubleshooting, feel free to ask me directly! Take care.
Posted on Aug 07, 2008
I have installed vista home edition on my pc and my headphones seemed not to be working on either the front nor on the backside green jack,the microphone are working fi9 and the external speakers are also...
Go to control panel, click on sound and check if the head phone jack is enabled and also if the drop down list under head phone jack properties states 'use this device'
I had a similar problem with my build in speakers on my laptop also in Vista and the problem was simply that the speakers were not enabled.
Hope that solves the problem for you.
Jul 24, 2010 | RaidMax Samurai 908 Yellow Mid Tower ATX...
I have a Skyhawk Aluminium 4698 ATX is it the same as the PSR4698
yes it is but the power supply puts out more watts on the skyhawk atx then the psr does.
Jul 12, 2010 | Sky Hawk Computers (PSR4698) ATX Mid-Tower...
Azza Orion front fan problem
Put some oil in the fan motor or check if any wires may hitting in the fan while running
Jun 15, 2010 | Azza Orion 201 black/silver SECC Steel ATX...
Headphones
Welcome to the computer age. I looked up your HP W1907 monitor. It comes with a built in microphone and speakers but no audio jack for plugging in headphones. You will need to find an audio jack on your computer tower. Most new computers have audio and microphone jacks on their front face. In most cases there will be a picture of a microphone or headphones next to the jack to tell you what it is. If you can't find one on the front, look in the back. The audio jack is usually color coded green. I hope this helps you out.
May 20, 2009 | HP w1907 LCD Monitor
Power Up ATX Mid-Tower case TC3j-4032 P Wiring
The front audio in this case does not support HD sound. To get it to work you must instal the "HD Sound Application" that came with your hardware and disable the "Detect Front Panel Jack Detection" option. You'll have to manually switch between the two inputs.
Mar 09, 2009 | Computers & Internet
Don't want to use my headphone, is there a way that i can just use my integrated computer's microphone
Hey,
Yes, sure, in the program you use the mic, you need to change the input or mic setting to the proper input, it debends. But try other inputs untill you find the right one.
Let me know if you need anything else.
Thanks,
Ekse
Feb 22, 2009 | Sky Hawk Computers (PSR5601W-SL) ATX...
My headphones won't work!
look at the headphone jack, if it has 3 band, it is a stereo jack. the computer is mono.
you need a 2 band jack.
if you look at the jack on the computer, you will see blue(left) and green (right). you canna try to use the green jack.
go to any electroic shop and get a stereo to mono converter.
Dec 05, 2008 | Sky Hawk Computers (PSR5601W-SL) ATX...
Front mic port and headphone
to connect your front panel header you must refer to your motherboard manual ...
it will given in detail with the pin diagram how to connect ....
check the motherboard compatibility some motherboards dont support working of the back panel header and front panel header at same time especially the old motherboards ....
almost all new motherboard supports working of both the panel headers at the same time if the motherboard supports multi streaming...
thank you
any doubts you can reply me
i am always here to assist you
bye
rate my solution
Aug 06, 2008 | Computers & Internet
Sound Issues w/ PSP-1000
Your headphone jack is probably damaged and needs replacement. Here is one I found on the net: Repair your broken "Hands Free" socket, soldering required. This item is also available pre-mounted to the board, ready to plug in. Free shipping.
http://powergamingparts.com/psp-socket-and-housing--replacement.html
Nov 22, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Headphone jack not working.
If you have a headphone jack at the front and the back, it may be a wire to the front panel is not connected properly on the Motherboard.
Aug 03, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Sky Hawk Computers (PSR5601W-SL) ATX Mid-Tower Case Logo
233 people viewed this question
Top Sky Hawk Computers Computers & Internet Experts
David Payne
David Payne
Are you a Sky Hawk Computers Computer and Internet Expert? Answer questions, earn points and help others
