Question about Whirlpool Dryers
Dryer quits MY DRYER STARTS FINE AND HEATS UP BUT QUITS AFTER A FEW MINUTES
  • 2 more comments
  • David Dickison Aug 07, 2008
    This dryer is about 10 yrs old Part # 3977842
    The model # LER5600JQ0
    My whirlpool dryer model # LER5600JQ0 starts but cuts off after a few minutes of getting warm then I can wait a few minutes and it will come on again but hten cuts off again
  • David Dickison Aug 08, 2008
    Yes thank you very much !
    President:
  • 2,712 Answers
Can u explain further pls?
Posted on Aug 07, 2008
  • Swilin Sampson
    Swilin Sampson Aug 07, 2008
    If your dryer doesn't work at all, it could be because of problems with:
    Power from the house
    Door switch
    Thermal fuse
    Wiring
    Check
    to see whether there's power getting to the dryer. Is it plugged in? If
    you plug something else into the outlet, does it work? If not, check
    for a blown fuse or tripped circuit breaker.
    Door switch
    If
    the door switch or the door-switch actuator is defective, the dryer
    won't work and you need to replace the failed component. The switch is
    inside the dryer main housing near the door frame. Sometimes you need
    to raise or open the top or front of the dryer to reach the switch.
    Thermal fuse
    On many dryers, there's a thermal fuse (a heat-sensitive fuse
    that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an
    inch long. It's usually embedded in black resin and mounted in a white plastic housing.
    If the fuse has blown, it has no continuity. When this happens, your
    dryer either just stops heating, or it doesn't work at all. Be sure to
    inspect the venting/heating system before replacing the fuse to put the
    dryer back into operation. (You can't re-set this type of fuse.)
    Wiring
    Often
    the main wiring connection from the house, at the dryer, burns and the
    connection breaks. In this has happened to your dryer, you need to
    replace the power cord and the terminal block inside the dryer to which
    the wire is attached.
DRYER RUNS SOMETIMES MID CYCLE DRUM QUITS TURNING BUT STILL HEATS UP COMES BACK ON AFTER A FEW MINUTES
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 26, 2011 | GE Dryers
Dryer heats up for a few minutes and then quits but dryer still runs
Hello
When the dryer heats for few minutes and then it won't work it means that the thermal fuse is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this fuse for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Speed Queen AES28AWF Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Gas dryer heats for 10 minutes then heat goes off
it's doing what it's supposed to do. you should use a different setting.
Sep 07, 2009 | Dryers
Dryer runs when first started, quits halway through drying cycle.
High temp. limit is probably at fault and will need to be changed.
Jul 13, 2009 | Whirlpool Dryers
Dryer will not turn on sometimes.
Bad motor no doubt about it.Act quick
Jun 18, 2009 | Kenmore 63942 Dryer
Dryer heats for 3 minutes, flame quits
the flame is suppose to cycle on and off. If the flame ran continously you would have a fire. And please don't use the top of it for anything such as clothes piles. Dryers need to be free of clutter on top. I know it may be hard to do but do it and your dryer will last you. Good Luck. Whatever you jumpered reverse it ok!
Oct 26, 2008 | Kenmore 73932 Gas Dryer
Quits heating
umm. what was original problem that made you change coils to begin?? no heat i would imagine.dont rush to judgement thatyour fix didnt work, if your running the dryer empty to test your repair,its quite possible that the dryer is going to heat to desired temp quickly, and take a while to cycle back on. throwsome wet clothes in machine and test it then.
Mar 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Quits heating
I would sugest you to replace the coil of the selenoids, after they get old, they dont work properly
Dec 14, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Kenmore Dryer works for about 20 MINUTES, not seconds
SD, doesn't sound like the same problem. Yours sounds more the like motor kicking out on overload and when it cools down you are able to start it again. The thermal fuse and high limit TCO are non resettable so you can rule them out. You are going to have to check some things out. Make sure the rollers and pulley are not binding. The blower wheel is not binding. These things will cause a drag on the drum and put a heavy load on the motor. Catriver...post back
Feb 12, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
13 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
