Euro-vox max when i turn the box over it comes up update code where do i get the codes from
  • 53 Answers
Call your sat service provider and they will be able to give you these codes
Posted on Aug 07, 2008
SOURCE:
How to fix a failed update in Italian
go to Microsoft's website and click products then click X-Box then put mouse over support and click X-Box 360 then click the third message down enter in you error code if nothing comes up contact Microsoft and tell them your problem.
Jul 31, 2012 | Microsoft Xbox 360 with Kinect Console
Navigon 7100 need activation code key for fresh maps
Activation cord is in the freshmaps activation card that comes with purchas of device.It is on the back of the card remove plastc with nail and you will get 15 digits number in 3block with 5 digits each.
May 05, 2010 | Navigon 7100 GPS Navigator GPS Receiver
I don't know my receiver code, i've tried putting in 1234 and 0000 but the it just keeps coming up with bad code please try again
Your question is listed under Sagem PVR6280 so I'll assume that's what you have. What follows also applies to the 6240, 6200 and 6200t.
There is another default code of 1111, if this does not work then there is a jumper switch inside the box on the main circuit board which will clear whatever code has been previously set back to the default code.
Open the box at your own risk and ensure that you physically disconnect the box from the mains and use an anti-static mat or an anti-static wrist strap. From memory, I think that when the jumper has been altered the box needs to be briefly re-powered and then turned off to allow the jumper to be reset back as it was.
If your box is a Sagem 6240/6260 then DO NOT update it yet as these models are known to be incompatible with the update and will lose some functionality afterwards. The official advice is to contact Sagem directly on 0845 0900 316 to see if they have a fix yet, but the number is clearly going to be ridiculously busy this week at least as thousands of their boxes are affected.
Cut and paste the web address below into your browser for the official line:-
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
I hope that you have found my answer to be useful and ask in return only that you take a moment to rate my answer.
Sep 28, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
TOM TOM GPS Updates
That depends on where you got it and if the documentation for the updates was in the box.
Usually the answer is yes.
Those from Tiger Direct do.
I have used it before now with few problems.
Couple of times I have had to talk to them but they have always been good and given me a code or new code to get the updates.
Jul 30, 2009 | Tomtom ONE 130 GPS Receiver
Code 401 comes on when checking codes
This is an airflow problem. Usually thought to be a EGR valve problem but the problem is the sensor not the valve. With OBD 2 you should have a DPFE sensor. (Delta Pressure Feedback EGR) that is a silver box with 2 hoses coming off the bottom that connect to the egr tube. That is the problem. Replace the sensor and your P0401 (that is the correct way to write the code as the P stands for Powertrain) will go away. The new updated DPFE sensor will be plastic and will probably require an updated connector. The connector should come with the updated sensor. And please use Ford Sensors.
Thank you for using FixYa - a FiXyA rating is appreciated!!
Jan 21, 2009 | 1997 Ford F150 Regular Cab
The box super usb
hi got a starview the box super usb, lost all discovery and music channels. can you help
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Need new codes for eurovoxmax
download BIGMAQ toolbar and it has all the latest codes on the toolbar.
*for irish users do not use the NTL tab code go into the IRELAND tab and select either ireland NTL or ireland CHORUS*
Dec 09, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox update codes
my euro-vox max channels not working please help me....
Oct 14, 2008 | StarTech.com StarView SV211K 2-port KVM...
Product code
Hello Lyndance678,
The maps should have come with an unlock code that needs to be input to install and activate them on the GPS. This code is similar to the product codes used by Microsoft and other software companies to prevent piracy. Typically the code should be printed on the CD jacket or on a certificate that came with the map CD.
Hope this helps,
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin Nuvi 370
77 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
