Question about HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 all in one
HI i cant find the disc that i originally had for my all in one. However i have plugged the usb cable into new laptop and the printer and copier works no problem but scanner won't work at all. Please help!
    Master:
  • 638 Answers
The fuller version is not loaded.the fuller version consists of all the facilities the printer has. load that from the 1210 installation disc.it will work. not a problem.
Posted on Aug 15, 2008
Can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
The hp director scan function no longer works properly. How can I correct the problem? Can I load just the hp director from the printer software?Printer is an hppsc 1210 all-in-one.
If this issue occurs, after installing the new version or revison of internet explorer then try to download the "Critical update to resolve an issue with HP Director after installing a new revision of Internet Explorer" from HP Website if the operating system is Windows XP.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=90764
If this issue occurs, in general follow the below instructions to solve the issue.
  1. Download the HP Officejet J6480 All-in-One Printer
  2. Install the HP Officejet J6480 All-in-One Printer while installing do not connect USB cable at any point of time if it asks, check USB connect later
  3. Download the HP PSC 1210 All-in-One Printer
  4. Install the HP PSC 1210 All-in-One Printer connect the USB cable when it asks to connect
Download the printer full feature software based upon your operating system.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3635378&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90764&lc=en&cc=us&dlc=en&lang=en&cc=us
This should resolve the issue.
Sep 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Computer won't recongnize printer
The problem is with the device driver. Every piece of hardware has a corresponding software program called a device driver to let Vista/XP know it is there and what it does and how to do it. If a disc came with your printer then that is what loads the device driver. However, with USB devices you must load the driver with the USB cable unplugged from the printer. Then once the driver loads then plug in the printer...nobody knows exactly why but that is with all USB devices. So unplug and load the disc, then plug and see if it works. You may have to reboot..if that does not work let me know as they are a couple of ways to get it to working. Good luck and keep me updated. Pls rate this solution.
Apr 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
After installing new original black & color HP ink catridges, still error "E" problem.. on a HP PSC 1210.
hi im josh in cebu phils.may i help you|? friend if your HP printer displays error after installing you orig.cartridges. the problem is in your software your software connections are already corrupting thats why he cant manage it to detect. all you have to do is re install your printer cd driver. but before installing the new one you need to uninstall or remove the old one first.thats all good luck hope i helped you
Feb 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 does not print at all
i dought dust would cause that, reboot pc and unplug printer
plug printer back in then turn computer back on, if still doesnt work try a different usb port
Jan 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
PC power resets w/ HP PSC 1210 plugged in
one of these updates causes a conflict more than likely a microsoft hotfix, try using a different usb port and unplug and plug printer back in
Scanning function
well i had the same problem but i suggst to do as the following to see if your problem could be solved you can try to restart the the 1210 or you didnt connect the usb cable rigth cause after you connect the usb cable you need to put in the deskjet disk that came with the 1210 and follow the directions from the wizard.
Dec 11, 2007 | HP PSC 1210 All-In-One InkJet Printer
My hp psc 1210 won't work with vista
I had a similar problem! Here is what eventually worked for me, after searching through postings for hours on end...
First, I made sure I had the new driver. Second, (and this might be different for you), my computer recognized my printer, but any time I sent something to print, it never made its way there. The little printer icon at the bottom said 1 document pending, then quickly said 0 documents pending, but nothing ever printed. When I ran HP diagnostics, it said everything was okay with the printer, and even printed a test page! But still nothing from any other program. So, eventually I went to control panel, then printers, then I clicked on the HP printer, then right clicked and went to properties. I changed two things in here, and I'm not sure which one was the solution. First, I changed the security settings (in the security tab) so that every user had access to all options for the printer. Second, on the advanced tab, I selected print directly to printer instead of the spool print documents option. And tada it worked!
May not solve anyone elses problem, but I didn't see this solution in any of the posting sites, so I thought I'd share it. Give it a try!
Aug 27, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
