Question about Cameras
Viviteck 3x optical zoom, battery door does not close
  • Anonymous Sep 10, 2008
    The battery door on my Coolpix 7900 will not close either.
I got an estimate of $125 to fix the Coolpix 7900 door, and the camera probably isn't worth that much. So I looked more closely at the camera to create a jury rig fix. As I never use a tripod with the camera, I thought about using the threaded tripod mount. I found a very short 1/4 inch thread screw in my garage and cut a thin metal strip to about 2 1/4" x 1/2". I then drilled a 1/4" hole at one end of the strip, laid the strip across the door and tightened the screw through the 1/4" hole and into the tripod mount. The door is now secure. To remove the battery, I simply loosen the screw a little with a dime and pivot the metal strip out of the way. There are many variations that can be done similarly such as using a plastic strip and a plastic 1/4" bolt or even a shorter strip that just covers the door.
Posted on Sep 12, 2008
SOURCE:
Removing battery
The battery door is on the bottom of the camera. Hold the camera bottom up with the battery door to your right. Slide the oval spring-loaded battery latch all the way to the right and gently pull up on the battery door.
Mar 20, 2014 | Nikon COOLPIX L6 Compact Digital Camera...
Transfer pictures from 813 3X optical zoom Camera to computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 16, 2012 | Kodak Easyshare C813 8.2 Mp 3x Optical...
What kind of charger does a Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot need
The DSCW80 Camera is supplied with the BC-CSGB Battery Charger which can be used to charge the battery of the Camera by inserting it to the charger.
You may also use the ACLS5K AC Adapter (not supplied) for charging the battery by using the Multi-connector cable of the Camera.
Thanks for contacting FixYa.
Feb 23, 2011 | Sony Cybershot DSCW80 7.2MP Digital Camera...
All of a sudden my kodak af 3x optical asperic camera would not turn on. how do I fix this problem?
Hello. This problem is generally due to a low or dead battery. Replace the battery or if rechargeable charge it. IF the problem is still there, take the battery and the camera to any radio shack where they will test the battery and charging system for you. J.
Jul 31, 2010 | Kodak Easyshare V1233 12.1MP Digital...
How do i use a san disc with a digital camera
You are able to use Memory Stick Duo and Memory Stick PRO Duo cards in your camera. The slot should be in the battery door or on the bottom side.
Apr 14, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Telephoto zoom
The D-565 camera has a 4x digital zoom, in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Simply use the Shooting Mode menu to activate the Digital Zoom feature.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Options for more telephoto zoom
The D-535 Zoom camera has a 4x digital zoom in addition to the 3x optical zoom, which gives you a total of 12x zoom overall. Press the Zoom button and a zoom indicator will be displayed in the upper right corner of the LCD – the area in white represents the Optical Zoom range and the red area represents the range of the Digital Zoom. The W represents a wider area of view as you zoom out, and the T represents Telephoto as you are zooming in closer to the subject.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Cameras Logo
124 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
