Question about Samsung Refrigerators
The fridge is too hot - Samsung Refrigerators
    Genius:
  • 1,142 Answers
See if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
My Fridge where the doors close is hot to the touch. This is a new problem that prior to today did not occur. I bought a new fridge and put the old one in the garage. It is plugged into a dedicated...
The hot temperature that occurs in the fridge body is normal and you have nothing to worry. It is the result of the heat pumps during a normal operation. Once the fridges reaches the normal temperature it will automatically shuts off and the hotness of the body will disappear.
Dec 01, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Overheating, seals on Roper side by side are hot to the touch
Hi, When that strip gets hot, it is a sign the temperatures are not cold enough. Put a thermomitor in the freezer. You should get a reading of 0 to 5 above. If not, let me know and we can try and get you through this.
Thanks
Vic
May 15, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Inside Not Cooling and Outside is Hot
possibly could ned a new comprossor for the fridge.
Apr 22, 2009 | Haier Refrigerators
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Hot coil?
Hello gaylekell,
Welcome to Fix ya
You said, you just opened your fridge a minute ago and it sounded like water or something is dripping on a hot coil at the bottom back of fridge.
It is in the auto defrost mode!
All frost free or self defrost refrigerators use this method of dispersing the water into the air as vapor.
As the water accumulates below the fridge is supposed to blow the water onto the hot coil or compressor and evaporate it away. That's why there are no more drip pans to empty!
If you do not notice any problem in the operation of your fridge
and it is not excessively loud, (Which I do not think it will be under a normal situation )
Your fridge is more than likely running normally and fine!
How old is the fridge and what's the model number?
Thank You for utilizing my advice, Huuum
Please remember to leave a rating!
Oct 03, 2008 | Danby Designer DAR1102W Refrigerator
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge has hot spot
Hit it with a big stick!
Mar 24, 2008 | Refrigerators
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Refrigerators Logo
50 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
