Question about Meade LX200GPS Telescope
Tracking ISS I have successfully upgraded my Autostar to 4.2g. Now , I would like to try to track the ISS (Meade manual says you can do it). How do I get the relevant data into my autostar i.e. for my location? (longitude and latitude are keyed into my autostar) . Any help would be greatly appreciated. Conn
  • galaxyman Aug 18, 2008
    Thank you for that most helpful suggestion. I have succeeded in getting the data into my Autostar. I await and look forward to some ISS passes and to trying to track it. Every time I learn something new about astronomy it opens up another exciting chapter. Clear skies!
Two Line (orbital) Elements (TLE) loaded from your computer to Autostar will do it. You can get the TLE from www.heaven-above.com ISS orbit
1 25544U 98067A 08223.18921414 .00008400 00000-0 64811-4 0 240 2 25544 051.6411 098.9613 0010451 052.2327 040.0128 15.72906000557033 This was for 08/10/08 and following days.You have to insert the TLE into Autostar by way of the #505 cable set.Then follow the instructions in the manual for a satellite. Anticipation and practice is everything.
Posted on Aug 10, 2008
Telescope control unit AUTOSTART failure
Unplug telescope from powe. Then reinstall software, it should fix it
Aug 04, 2008 | Meade 494 AutoStar Telescope Control Unit...
I have six Meade ETS-LX 6" telescopes which are used in an introductory astronomy lab. I have upgraded the firmware and other files in three of the six and they are working fine. The other three do...
These scopes have many bugs in the firmware and are not a mature technology. Some people have issues and some do not.
About the only thing you can try is to reload the firmware using the SC CARD method. Contact Meade or read the manual to learn how to upgrade the firmware using an SD flash memory card.
Other than that the scopes will need to be returned to Meade for repair.
Mar 07, 2011 | Meade DS-2130 (350 x 127mm) Telescope
Trying to install Autostar Suite. At the point where it is updating system configeration. Just keeps on going and going and going?
Did you get the latest version off of the Meade web site here:
http://www.meade.com/support/AutostarSuiteWebEdition55.exe
Try it--
Mar 01, 2011 | Meade Autostar Suite Autostar Suite...
My telescope-Meade LX200GPS when tracking the star,it can catch it in some minutes ,but later the star out of eyepiece,is it not tracking the goal? when I tracking the jupiter,the telescope can find the...
To track the scope must:
1. Have a Calibrate motors done
2. Be well Trained using the training routine
3. Must have the correct TIME, DATE, and SITE, and Daylight Savings Time
4. Must be properly aligned on two stars.
Have you done all of the setup procedures listed in the manual? Locate a local Astronomy club and the members will help you with your telescope.
Nov 13, 2010 | Meade LX200GPS Telescope
Set up autostar
You can get one off the Meade web site here:
http://www.meade.com/manuals/index.html
Find your telescope on the above page and download a free manual.
May 01, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
I lost the cd for my autostar, how can i get a new cd and instrution book..
All programs and manuals are available for download from Meade.
www.meade.com
Sep 08, 2009 | Meade Autostar Suite Autostar Suite...
Where can I find instructions for the Meade 114 mm Autostar telescope
All of Meade's manuals are located here--
Jun 14, 2009 | Meade 4.5" Telestar tonian Reflector...
No horizontal movement of autostar
Here is Meade's manuals web site--
They also have a customer support phone number-
www.meade.com
Either the gear is loose and not engaging or is broken-- or the clutch is not engaging when you tighten the base.
May 19, 2009 | Meade Autostar Suite Autostar Suite...
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Meade LX200GPS Telescope Logo
464 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
