Question about GE PDS22SBRLSS Bottom Freezer Refrigerator
Fridge is not cooling and now the freezer is not freezing
The fridge has not been cooling for a week now but the side freezer has been ok .Now the freezer is not freezing and there is frost built up on back wall a little.This is a GE 5 year old side by side model that is frost free.
What kind of repairs am I looking at,how costly and should I just plan on getting a new unit?
    President:
  • 1,462 Answers
Problem is that the defrost system is not working.
remove back panel inside freezer and you will find pipework is full of ice. melt off carefully with a hairdryer. appliance will now work as this serves as a temporary repair
fault finding is not so easy but check that the defrost heater is not open circuit and check the thermal fuse in series with the heater is ok.
some frostfree are controlled by a simple mechanical timer which can also be faulty. if electronically controlled, you may be looking at a new module. get back to me if you want more help
Posted on Aug 07, 2008
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
Freezer side freezes up after 1 week, cool air can't get to fridge, start warming up.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 03, 2011 | Refrigerators
The freezer gets really cold but the vent that runs from the freezer to the fridge freezes up and the coils also. when i clean the coils and the freezer vent it works great for 2 weeks then it starts to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 03, 2010 | Maytag MSD2656G Side by Side Refrigerator
The refrigerator side started not cooling last week just half way up the fridge. Now the freezer half way up is not freezing.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
dhjhdg
Oct 26, 2009 | Samsung 26 Cu. Ft. Side-by-Side...
Fridge freezer side by side running constantly but not cooling.
Make it a habit to defrost it every week. You see, when ice forms around the evaporator tubes (which runs around the walls of fridge and freezer), heat exchange reduces (that means heat is no longer absorbed from the things inside the refrigerator) and cooling stops. See whether freezer walls or fridge walls are damaged. Do not use knives or any other sharp tools to remove ice. Do not forcefully remove items that are difficult to take out from the freezer. Defrost and remove them.
Aug 12, 2009 | Freezers
GE PDS22SBRLSS Bottom Freezer Refrigerator Logo
135 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
