Question about Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg dishwasher tripping out fuseboard
I have a Smeg DWD1SSE-1 dishwasher that has started randomly tripping the breaker on my fuseboard. I initially thought it may be the heating element, but after restarting the dishwasher I found that the water was getting hot. I then wondered if it could be the thermostat in the dishwasher. As there is only a vague timer that seems to be different on every load, I cant fathom out at what stage of the wash is causing the problem. Any help or advice on this situation would be much appreciated.
Cheers, Rhod.
  • 258 Answers
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Posted on Jan 18, 2009
Testimonial: "Sorry it has taken so long to get back to you......forgot the log in details and sorted it in the meantime. Thanks for replying though. :)"
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
E5 smeg dishwasher
Water inlet solenoid valve faulty. Check this is voltage to valve when water should be flowing. Replace valve if there is voltage present.
Jun 04, 2014 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Replace heating element in smeg oven
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 02, 2013 | Smeg Ovens
Blows mains fuse
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
Machine not takin any water
Before starting a washing program make sure that:
• The water supply tap is open.
• The correct amount of detergent has been added to the
dispenser.
• The baskets have been correctly loaded.
• The spray arms are able to rotate freely and without
obstruction.
• The dishwasher door is securely closed.
After you check all start the dishwasher again.
Jun 05, 2011 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Hi smeg se210x/1 doesnt want to heat up to a decent temperature?
May 30, 2011 | Smeg SE210X/1 Stainless Steel Electric...
I have a smeg oven model SE335SS-5 I think that the element has gone however there is no obvious damage to the element. When I was cooking the house circuit breaker tripped and the oven works fine apart...
Feb 13, 2011 | Smeg Ovens
Won't empty
how old is it if its more the 1 year buy a new one but if its not just get it fixed
Jun 01, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg 24 in. DWD1SSE-1 Built-in Dishwasher Logo
978 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
