Samsung 21inch tv turned of while watching tried fuse still not working making a low ticking noise with the back removed?
  • icemaiden537 Aug 08, 2008
    yes it is is there any way to fix this or is it a big job?
    Genius:
  • 1,011 Answers
Is the noise coming from Flyback (a big greyish color unit inside the board, having a connector from picture tube).
if yes, then it could be caused by this..
regards,
Posted on Aug 07, 2008
  • SALMAN NASEER Aug 08, 2008
    dear,
    you have to change it.. dont try to repair it.. it is dangerous..
    b'coz it transfers the thousands of volts to the pictures tube.
    you u try to repair it it will leak and cause very serious problem..
    thankx.
    regard,
    dont forget to rate
Makes ticking sounds and wont work
The ticking noise is either something touching the fan in the Fan Assembly; or the Harddrive has gone bad.
My thoughts?
Harddrive
http://www.youtube.com/watch?v=ZGqaz4JdS5E
http://www.youtube.com/watch?v=YqgkqcNCrj8
http://www.youtube.com/watch?v=FjYuzjA31mQ
Regards,
joecoolvette
Dec 29, 2012 | IBM Lenovo ThinkPad X41 Motherboard...
I have a ticking noise when i try to turn on the tv..
Try putting on the back piece. Some of these TVs have a circuit protection system that will not deactivate with the back open. (It is like an old circuit breaker with the fuse out.)
I hope this helps.
Jun 03, 2010 | Philips 50PL9126D/37B 50" DLP TV
My samsung WS32Z306V WONT TURN ON AND JUST HAS A TICKING COMING FROM THE BACK PLEASE HELP
Hi, Sorry this is not a fix but i wanted to say that i have the same problem on my tv which is the same model as yours.
At start tv would show faint parallel diagonal lines until some day it stopped working. Everytime i try to turn it on it doesnt! and makes a ticking sound from the back of the tv. Did you fix yours btw?
Feb 22, 2010 | Samsung WS32Z308P 32" TV
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Car wont start, contstant ticking from engine.
Locate the ticking noise. It is a relay that has gone bad.
Jan 12, 2009 | 2003 Renault 181
Samsung DLP 42" watching tv when tv popped and went off, then tried to turn back on and tv made a sizzle noise.
Process of elimination with a volt meter. Plus when I removed the lamp cover glass went everywhere so that pretty much told me the lamp was toast. Thanks for your response.
May 31, 2008 | Samsung Televison & Video
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Samsung TXM3296HF problem - tv won't turn on
your flyback transformer could be your problem or in the video circuit.have a tech look at your tv for possible repairs.good luck.
Apr 01, 2007 | Samsung TXM3296HF 32" TV
TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Mar 30, 2007 | Philips Magnavox MT1905B 19" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
