Question about Sharp AL 1631 Copier
Wont copy anymore
A little red light comes on and it wont copy anymore. Sounds like it wants to pick up the paper and pass it through but cant.
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
What is the red light ? what symbol does it look like?
Posted on Aug 07, 2008
Am repairing a canon ir1020 which shows paper jam for any single copy.though paper is completely delivered out of the fuser ,but the red in response to paper jam still flashes.I need an assistance.
Sounds like the fixing exit sensor flag is missing or broken. I would look into that and just a note... I had a strange jamming problem with one as well. It turned out to be the registration clutch. I cleaned the clutch and it worked......
Sep 01, 2012 | Canon IR-1022 Copier
Red light stays on... wont print wont pick up paper... cleaned as much as I could...
There are a lot of conditions that cause the red light to come on. These include toner cartridge empty, paper jam, waste toner tank full, etc. The only good way of determining the printer fault is to check the smart panel software on your computer. It will tell you what the printer is experiencing.
If the printer can't pick up the paper, check the condition of the paper pickup roller. It is located in the back, and above the paper tray. Often it get dirty and cleaning it with a damp cloth helps it to pick up paper better. Hope this helps you.
Dec 29, 2010 | Samsung CLP 300 Laser Printer
My copier wont pull the paper from the has a full load of paper in it but when I go to try and make the copy it won't pick it up and then it flashes "P" like it is out of paper
Have you taking out the paper tray and look inside for a piece of paper jammed behind the paper tray. Also, make sure the paper guides in the paper tray are tight against the paper in the tray & make sure the copier is on a level surface. You may also, need the paper feed rollers or clutch. If you need to make copies, use the by - pass tray on the right side.
Apr 05, 2010 | Sharp AL 1631 Copier
Paper will not feed and sounds like it wants to catch paper then red light comes on?
You just take out the toner cartridge and paper guide, and clean the roller in the back center with a damp rag, should pick up paper again after that cleaning...
Oct 09, 2009 | Samsung ML-2510 Laser Printer
Printer shows a red light for paper. It will not
Remove the paper tray and clean the feed roller with alcohol or water.
Oct 04, 2009 | Brother HL-2040 Laser Printer
1984 toyota camry no brake lights switch fuse and bulbs are good
check wiring further back in boot rh side there is little black box that plays up fitted there.check this cant get anymore must by pass box now.
May 31, 2009 | 1984 Toyota Camry
My copier does not pick up the paper anymore.
If your copier isn't very complex in its design, you may be able to locate the little rubber wheels that pull your paper in initially. If you can get to them, I recommend spraying them with some rubber rejuvenator. This will not come off on any future copys, just follow the instructions on the can. If the issue is a lifting mechanism, that will require parts and possibly a technician. Let me know!
Mar 25, 2009 | Xerox 8830 Copier
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Red light on Printer doesn't want to print anymore
pull out the cartridge and look for paper inside, re-install cartridge, also look on the back part where the fuser and exit assembly is look for paper jammed. also make sure the paper is set correctly on the tray.
Jan 06, 2008 | Brother HL 1430 Laser Printer
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
