SOURCE: How to replace a pickup roller in Tray 2, HP LaserJet P3005n
please reference here:
https://www.laserpros.com/hp_P3005_tray_2_pickup_assembly.asp
hope you fix it well
SOURCE: Getting the error on my HP 4345mfp - TOP OUTPUT
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
SOURCE: how to make default tray
HP printers will default to the highest numbered tray that contains plain letter paper. So on a standard 3005 Tray 2 is the default unless you have the paper type set for something other than plain letter. If you have an additional tray, then Tray 3 would become the default tray if it is set to plain paper. In this case, you would set tray 3 to either bond or letterhead so that the printer would only grab from that tray if you request either tray 3 be used or create a job that calls for that type of paper.
If this does not sort it out, post back again with a complete description of the printer including number of trays, what is loaded in the trays and how they are set for both paper size and paper type. This information can be found by printing a configuration page. This is done by pressing the arrow key on the control panel until display reads information, press checkmark (green button) then use down arrow until Configuration page is displayed and then press checkmark again. Page will print that shows all the settings for the printer.
