Question about White Sewing 1632 Mechanical Sewing Machine
Needle won't move
I have a While sewing machine. When I press the foot, the needle does not move up and down. When I tried to move it manually, the knob won't move. Any ideas?
    New Friend:
Please push the bobbin winder back to the left position and it will release the bobbin winder. Then you should be able to sew. If the needle won't move, you will need to tighten the turning wheel on the right side end of the machine. This should move your needle. Then you should be set to sew. This should help, it helped me!
Posted on Jul 19, 2012
  • pamela
    pamela Dec 07, 2013
    This machine doesnt have a tention knob so this problem is very fustrating ive tried every thing to get it to work
I had that problem too! I usually turn the tension knob and it works,
Posted on Sep 27, 2008
6ya staff
SOURCE:
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Singer confience stylist beeps four time and won't let me sew
The beeps usually indicates that your machine is not ready to sew which probably means a function has been left in the activated mode, ie bobbin winder, buttonhole function, etc. . Here are some ideas:
Why does the electronic beeper beep and the sewing machine won sew Sewing...
20 Most Recent Singer 7467S Confidence Stylist Electric Sewing Machine...
Mar 05, 2018 | Singer 7467S Confidence Stylist Electric...
Needle arm stuck
Firstly, do you pull the fabric as it goes through the machine; this is a surefire way to break needles. Tension imbalance shouldn't be breaking a needle; more likely the thread would break if the top tension is too tight. And botton tension shouldn't need adjusting at all.
It may be that your needle is striking the presser foot if you are applying some "pull" to the fabric at the back of the foot.
But sewing very heavy fabrics is a challenge for many domestic machines - upholstery, heavy denim and canvas is tough going for many machines. Some tough mechanical machines will manage it but many won't. You can try using a roller or walking (even feed) foot as this may help with moving the fabric through but often the feed dogs just can't grip and move the heavy fabric enough. If you need to sew heavy fabrics regularly maybe consider finding a 2nd hand industrial straight stitch machine such as the Singer 20U.
In the case of your Bernettte, remove the needle plate (two screws), pressure foot, stub of needle and bobbin and then search the bobbin rotary hook area and see if there is a piece of needle stuck anywhere, you may need to turn the machine upside down and see if it falls out of the race area. I think this machine has a plastic horizontal bobbin case ??? If so, you will probably find that this has dislodged and may have been struck by the needle so remove it and give it a good visual check for damage, if there is a pierce mark, then give this a file down with an emery board to smoooth it. While it is out, see if the flywheel will now rotate the rotary hook fully.
Then reassemble by putting the bobbin case back in lining up the mark on the case with the stopper in the rotary hook, replacing the needle plate, pressure foot and a new needle.
If you can't get it to unlock at all, then it will need to go to a technician for repair.
Nov 07, 2011 | Bernina Bernette 75
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
Beginner on a sewing machine just got a Euro- Pro from my aunt having a hard time getting it to sew something. I threaded it and ready to go now it wont sew soooo what might be wrong with it?
See if you can find your model here and refer to the instructions to see if you missed something when you threaded the machine - http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Always thread a sewing machine with the presser foot up so the thread enters the tension so it will properly work when the foot is down for sewing.
Check the needle to be sure it is inserted correctly - this is usually with the flat side facing the back of the machine.
Hold onto the thread tail at the needle and handwalk the needle down and back up, which will bring up the bobbin thread.
Hold onto both threads and pull them under the presser foot and to the back of the machine.
Place the fabric under the presser foot. Lower the foot and move the needle down into the fabric - press the foot pedal.
Feb 28, 2010 | Euro-Pro Sewing Machines
Have Viking Husqvarna #1+ sewing machine that when filling a bobbin caused the bobbin to overfill and break. Now when pressing the foot pedal the needle will not move. I can manually turn and get the...
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Feb 02, 2010 | Husqvarna Sewing Machines
White Sewing 1632 Mechanical Sewing Machine Logo
790 people viewed this question
Top White Sewing Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
radcal
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
