Question about Jenn-Air Kitchen Ranges
I have a jenn-air electric grill range cooktop. One of models c116c, c206-c, c236-c or c316-c (according to the manual. One burner is not working. I have replaced the burner itself and it still does not work. I am wondering if the part number 204127 might be a fuse and if so if it could be a factor in the problem i am facing. Also is it possible to buy another such part?
SOURCE: jenn air range, model CVG4280B,
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Posted on Jul 13, 2008
SolutionGuy
  • 331 Answers
SOURCE: Worth fixing 2005 jenn air elec downdraft cooktop?
"Breaker tripped and all power blew when stove not in use. Can't turn breaker back on. Repairman thinks it is two switches since the wouldn't turn on. He fixed them so they didn't stick - but still tripper blew but at least not all the electricity."
Oban, This does NOT sound like a cook top issue --> "blew when stove not in use", "Repairman thinks it is two switches" (I assume you mean the breakers),
I could go on and on.... but what I've seen with these is improper connection at the junction box. In other words, whoever wired it up, screwed it up. Look at #4 in this diagram. The problem is happening here.
"He fixed them so they didn't stick"....Oban... the reason a breaker is there is to trip when there is a short circuit. It is most definitely NOT there to be bypassed! You may consider RE-considering your choice of electricians.
Go outside and kill the breaker. Then open up the junction box (you have to open the doors below the cook top). When you remove the cover of thew J-Box, I'll bet you see burn marks (if not melted plastic).
Check it out.
SG
Posted on Apr 22, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
SOURCE: Jenn-Air JGD8130
i have the same problem.. jgd8130.. can i change out the burners or orfices..etc to make one or two of the burners for more btu's? ro9beam2002@yahoo.com
Posted on Jul 08, 2010
I purchased a house w/ a Jenn-air elect. drop-in range. The Model # is 87946 or 87847. I believe the range was originally purchased in 1975. I am in need of an instruction manual .
Neither of these are a typical Jenn-Air model number. http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US suggests that the model number is on the back wall under the burner on the right side of a drop-in cooktop. For a range the model number is often on the frame inside the oven door, below the vent or on the back of the top of the range.
87946 or 87847 are the part numbers for the cartridges (the elements or the surrounding housing).
Look at the model number locations at the "Help me find my model number" link and try to locate a model number on your range. Then enter that model into the search box. The manual is probably available with the correct part number. Most Jenn-air electric cooktops start with JEC in their model number.
I hope this helps you locate the manual.
(I did try JEC87847 just in case you left off the leading alphabetical characters.)
May 08, 2011 | Jenn-Air Microwave Ovens
3 of the 4 burners clicks and sparks when I try to
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jul 27, 2010 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Use and Care Manual for a 89353 Tri- Convertible Grill Range
You can get parts for you cooktop on the link below. just click on the area that needs the part.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=89353-8&productCategoryId=0121060&brandId=1266&searchedModel=
As for the manual you might beable to get one from your local sears part department.
Good Luck
Jul 01, 2010 | Jenn-Air JED8230 Electric Cooktop
I have a Jenn-air, C206-C model grill-range cooktop. Three of the 4 burners have stopped working. Any solutions?
heatman101
Jun 04, 2010 | Jenn-Air JED8230 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn air range
1.black top nice and shiny, as far as streaks your gonna ahve to find a cleaner that works for you , i have a black cooktop and my wife uses clorox wiped to clean and then with paper towel wipes off and dries
2. as far as "saddle grill" calling the manufacture (number inside your manual) will be best source of info on that, of course unless you can find an aftermarket 3rd party maker
Mar 15, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
