Question about Henry Numatic "" Canister Vacuum
Henry's motor burnt out
I was using my Henry there was a flash and a horrible smell and it sounded like a bag of hammers. I switched it off dismantled it but there is no sign of a burn out although it clearly has burnt out. I ordered a new motor which when it came had the terminals in different places and I am not sure which terminal on the new motor corresponds with which terminal on the motor I removed is a wiring diagram availablel that would help ?
Henry numatic: 2 white wires do these go opposite or side by side
Posted on Sep 05, 2009
    Scholar:
  • 192 Answers
You should have 3 wires one of them are green . gr. is the ground . the other 2 are interchangable. good luck DFD
Posted on Apr 13, 2009
Machine was running, it quit and has not ran since. This happened last week. I did change out the switch thinking that may be the problem.
Proteam Pro Force 1500XP Bagged Upright Vacuum
Tom, the motor has probably burnt out, if you dismantle machine you could test motor directly to prove faulty or just replace machine.
Mar 31, 2016 | Proteam Pro Force 1500XP Bagged Upright...
Why is my henry vacuum cleaner not working motor running but no suction ?
Hi I will try to guide you though this problem.
When you switch it on do you get air blown out of the vent on the machine housing.if not there may be a blockage.
if you take the hose off, do you have suction on the main body.
if so pipe is blocked.
if no suction then, do you have a bag in it. If so remove the bag and reassemble and try again.
there should also be a sealing ring with a fabric on it between the motor head and the body, is this very dirty or missing.
if none of the above works then I would assume that the fan is adrift on the motor.
i would advise a qualified person investigates further as risk of electric shock if you dismantle the advice.
please let me know how you get on.
Sep 09, 2014 | Henry Numatic "" Canister Vacuum
I'm getting a horrible sour/sweaty like smell blowing out of my Henry when vacuuming, i've tried to clean the filter, but its still just the same & the smell also seems to be in the head o
You can buy little sachets of nice smelly stuff to put inside Henry. Most supermarkets have them. Makes the carpets smell nice too.
Feb 07, 2013 | Henry Vacuums
I have taken henrys lid off to look at the motor now he has stopped working
It's possible when you took the lid off one of the wires has come off a switch or the field. It could also mean the motor has gone. Recommend you get it checked out.
Dec 10, 2012 | Numatic Henry Bagged Canister Vacuum
My Henry the Hoover has stopped working, I turned it on and it just stopped and there was a horrible smell.,
It sound like you burned it up when the bags fill on these uprites people keep using them the dirt gets in to the motors and burns them out I would say take it to your vacuum repair
Feb 10, 2011 | Hoover Vacuums
Motor is making a strange noise and smells of burning
The motor needs to be replaced. Unless your Henry is still under warranty it's cheaper to buy a new one.
Sep 20, 2010 | Numatic Henry Bagged Canister Vacuum
Wet vac motor making noise and smells like burning
Hi I would suggest that the burning smell and the noise will mean that the motor is burnt out. You can get them pretty cheaply from the internet and they are quite easy to fit.
Mar 04, 2010 | Henry Numatic "" Canister Vacuum
Water in Henry vacuum cleaner motor.
I would say it's essential to open Henry up, otherwise (assuming he has indeed got water inside him) you will wait for ever for him to dry. He can be opened very easily - just undo the four recessed screws on the underside of his hat, and the upper part will lift off. Pay attention to the switch (or switches, depending on the model) as that may be more vulnerable to water penetration than the motor. The motor compartment may have water in it, but the motor itself is probably fairly well protected. When you've got it opened and mopped up any visible water, it will help to give it a blow with a hair dryer.
If in doubt, though, get a professional to deal with it. It pays not to mess with electricity if you're unsure!
Jan 06, 2010 | Numatic Henry Bagged Canister Vacuum
My hoover smells of ammonia
I too have a problem with a bad smell coming from my henry hound hoover, but thats probely because i haven't used a hoover bag. I took the cloth filter out,banged all the dust off, then sprayed it with 'RugDoctor' pet stain remover for carpets and upholstery. It still smells a bit, but not half as bad as befor. I have now ordered a reusable,zipable,washable cloth hoover bag especially made for Henry's. It cost £8.80 from ebay with free postage. Hope this helps Nikki.
Oct 30, 2009 | Numatic HHR-200 Henry Hound Bagged...
Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Feb 28, 2009 | Numatic Henry Bagged Canister Vacuum
Henry Numatic "" Canister Vacuum Logo
1,078 people viewed this question
Top Henry Vacuums Experts
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Henry Vacuum Expert? Answer questions, earn points and help others
