SOURCE: Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
SOURCE: sony vaio pcg-7v2l
As you boot up press the F8 function key, you will then be able to select Last Known Good Configuration, if you are lucky Windows wil start up OK.
If not shutdown and restart again and press F8 again, this time select Safe Mode, this time if Windows starts up the screen resolution will be standard VGA mode. You will then be able to work out what is wrong.
If this doesn't work you will need to boot up with the Windows CD and do a system repair.
If this dosn't work you will need to do a complete reinstall of Windows plus the device drivers and all your software programs. Note - you will lose your data in this process.
SOURCE: sony vaio hangs on start up
Try to restore your PC.
Solution:
-Programs
-Accessories
-System tools
-System restore
5. select on the dates that your system was still running
normally.
If this solution helps you, please rate me.
Thank you.
regards,
-engrkoiled-
SOURCE: Laptop screen flickers and goes off .
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
