Question about Zenith C27V36 27" TV
Zenith c27v36 My Zenith TV has a built in tuner but hi def has to use a cable box.Will I need a digital converter box for my c27v36 model if I want to use an off air signal after the digital change over in February?
  • jmv567 Aug 19, 2008
    I am wondering the same thing. I lost my manual and Zenith web site no longer shows this model number. Thanks.
  • 4,234 Answers
The short answer is no. You will not need a converter box. This set contains the ATSC tuner required for the new over-air signals.
Dan
Posted on Mar 04, 2009
How can I get analog channels to work with DTV without cable
Hello drandald,
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
-Joe
Aug 29, 2011 | Zenith Z32LC2D 32 in. LCD Television
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
Converter box question
This set has the ATSC tuner required for the new over-air standard. No converter is needed.
Dan
Mar 04, 2009 | Zenith C27V36 27" TV
How do I scan for channels with my RCA converter box
The remote should have a scan button on it.
then the screen go thru it process and it should say done
Feb 18, 2009 | Zenith C27V36 27" TV
Zenith 27" HDTV second antenna input not accessible on TV/remote
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
Feb 10, 2009 | Zenith C27V36 27" TV
Digital ready?
Deacon J,
You will need a digital converter box OR high definition tuner for the transition. What's the difference? A converter box will only output a standard definition signal, either on channel 3 or by composite or S video cables. A high definition tuner will allow you to watch the new digital broadcasts in hi-def, assuming they are transmitted in hi definition. The converter boxes are the cheaper option and you can get a coupon from the government for a $40 rebate on the box, but I would opt for the hi-def tuner fo the better picture quality.CNET has a good write up on the transition here:
http://www.cnet.com/1990-7874_1-5108580-3.html
I did some looking and about the cheapest hi-def tuner I could find was $150, which is 3 times what a converter box would cost. I would expect the cost to fall on the tuners over time. Perhaps a converter box may be a good solution until the prices fall, if they do. The problem is that not many companies are making the tuners, as most TV's already have a hi-def tuner built in, so there isn't a big market for the add-on tuners. I hope this answers your questions.
Dec 31, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Digital boxes
This model only has an analog tuner, so you will require either a converter box or hi-def tuner after the transition.
Dec 07, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Cable box
Yes, this TV will need a converter box if you are getting off-the-air reception. It does not have a DTV tuner built in (too old) although is a high-def capable set.
Dec 06, 2008 | Mitsubishi WS-55807 TV
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
Zenith C27V36 27" TV Logo
147 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
