Question about Pioneer DEH-P2000 CD Player
Pioneer DEH-P2000 when i turn it up it comes out bad and crakilly and it not my speakers is the wiring but dont know what sam g
  • sjgtrac Aug 07, 2008
    Problem Solver:
  • 20 Answers
It sounds like you have a positive and negitive touching each other or one wire is exposed and is touching metal. Pull it out of the dash and check you splice/connections.
Posted on Aug 07, 2008
I dont know wich wire to put where on my ignition of my hyundai elantra 1996 car
If you purchased a wiring harness adapter for the vehicle, which you should have, you simply connect all the same colors from it to your Pioneer and insulate any wires with no match, then plug in the connectors.
Dec 14, 2013 | Pioneer DEH-P2000 CD Player
I am trying to find a Pioneer DEH-P2000 Schematic diagrams.
schematic for what.....All name brand radios have a standardized color codes coming off the harness.
Yellow- Constant
Black- Ground
Red- Switch power
Blue- Antenna
Blue/white- Amp turn on
White- Left front +
White/black- Left front -
Gray- Right front +
Gray/white- Right front-
Green- Left rear side
Purple- Right rear side.......the black stripes are your negative speaker outputs.
Feb 24, 2010 | Pioneer DEH-P2000 CD Player
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Wiring my pioneer deh -p2000 to my speekers
Check the back of your receiver, to see the plug with a set of 8 wires that should have the following color standard:
Left front: White
Right Front: Grey
Left Rear: Green
Right Rear: Purple
Note: 1) Colored wires with a line/stripe on it is NEGATIVE, thus connect to negative on speaker. When connected, speaker cone should vibrate OUT, not inwards, otherwise reverse speaker connection;
2) You can check to see if speakers are in the right order by 'panning' balance and fader controls (from left front only to right front only, to right rear only, to left rear only in succession)
3)If there is an amplifier in your setup, the RCA plugs (like home audio plugs, should be connected instead, NEVER both!)
Hope this helps
Mark
Sep 25, 2009 | Pioneer DEH-P2000 CD Player
I dont know wich wire is for what for Pioneer DEH-P2000, i need a wiring diagram or manual
black ground red accessory (KEY) yellow memory constant power,blue is remote,orange is for the dimmer,green with black is left rear neg.and green is positive,violet black is right rear negative and violet is positive,white is left front positive and white with black is negative,gray black is right front negative and gray is positive
Jun 14, 2009 | Pioneer DEH-P2000 CD Player
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
How do I know if a new/used car cd player will fit?
yes.......... just buy a mounting kit for your car and a wire harness for your car.........to install just unplug factory radio and clip the harness on to factory plugs that you just unhooked from factory radio now just attach the same colour to colour wires from your new deck to the harness......mounting kit comes with instructions
(make sure to buy WIRE HARNESS & MOUNTING KIT for your car) and your install should take less than a hr to do
have fun
Feb 18, 2009 | Pioneer DEH-P2000 CD Player
Wiring diagram
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Aug 07, 2008 | Pioneer DEH-P2000 CD Player
PIONEER DEH-P2000
Goto www.installdr.com. They have all wire diagrams.
Jun 04, 2008 | Pioneer DEH-P2000 CD Player
Pioneer DEH-P2000 CD Player Logo
67 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
