You have a hardware device or memory module or a part that has gone bad maybe loose or just needs to be changed out. Most likely it will be a memory module or a keyboard or a USB device unplug any of those items then restart the computer and see if the beeping stops.
Also you can remove a memory stick one at a time to see if the beeping stops if it does then you have found your issue. Also unplug the computer from the wall socket and push the power button in for 2-3 seconds this resets the computer to load its defaults. Look for the issue one by one and with the power button pushed after you unplug from the wall and ground yourself by touching the case metal before you touch parts inside the computer. I use latex rubber gloves personally.
Replace and go from there. It is about isolating the problem now to stop the beeping. So give that a try it is nothing that you have done it is the computers method of letting you now something is not working that is all. Thanks for using FixYa! John
Testimonial: "Excellant deduction and explained like pro. It was the memory sticks. I removed them and replaced them and "bobs your uncle" problem solved. Thanks "
Just refix the RAM sticks ,,It will work fine
Testimonial: "Spot on and resolved this for me.. Thanks Muchly"
