Question about IOGear GNS1000 (881317000101)
Cant connect to web gui
My problem is that the web gui will not come up when I connect to the default address through IE. However, I can execute a successful ping. In addition I did try resetting router
Thanks in advance for your suggestions
  • Anonymous Jan 05, 2009
    I have the same problem
    Problem Solver:
  • 10 Answers
Use Opera browser any version
Posted on Feb 02, 2009
The gui setup wizard is not popping up/opening and i cannot access
If you're using Windows, plug the ASUS device in via wired (ethernet). Hit Start, then type in CMD, then type in ipconfig. Look for wired local area connection. Do you see That's probably the ASUS. Now, type that in your browser. Voila, the GUI should pop up. It worked for me.
Oct 10, 2012 | ASUS EA-N66 Dual-Band Wireless-N900...
Where can I find my wireless key?
Try to access your router's gui. To do this, you have to use your internet explorer.
1. Get your default gateway address first. a. press the windows key + R b. type cmd then press ok c. on the black screen type ipconfig then press enter d. look for the default gateway address 2. Type the default gateway address on the internet explorer address bar and you will be able to see your router's gui
3. Refer to the manual posted on the link below. Refer to Chapter 7 to get the WEP key of your router.
note: you need to connect wired to your router before anything else.
Netopia Wireless Router Manual
Jul 08, 2011 | Netopia (3347NWG-VGX) Wireless Router...
Wireless capability is turned off--how do I get it back
usually one can access the webGUI and enter there password (usually default)
access the GUI by opening firefox or IE or chrome or there web browser and plugging in an ethernet cable then go to (address bar): (belkin usually) (linksys usually)
this depends on your computer configuration.
there should be a wireless tab, click it and it should say disabled.
Feb 28, 2011 | Computers & Internet
I have a router i forget everything to it i cant get into it at all cant access the internet or nothing
To access a router on which you forgotten everything, do the following...
1. apply power to the router and connect an ethernet cable from PC to one of the router's LAN ports
2. press the router's reset button (usually located beside its power supply jack) for at least 5 seconds
3. (pressing reset for 5 seconds resets the router to its factory defaults)
4. with factory defaults, you can now use the Setup Wizard on the router's Setup CD-ROM
5. if no Setup CD or to configure advanced settings see router manual about web-based utility
6. open Internet Explorer and enter the router's default IP address (see router manual for address)
7. IE presents a login window for entry of router userid and password (see manual for defaults)
8. once into the router's Basic Setup screen, follow the steps in the router's manual to do the setup.
9. if your ISP requires a registered MAC address, enter it on the clone MAC address screen
10. for better wireless security, change router SSID from its default and enable WEP or WPA
Feb 22, 2011 | Computers & Internet
Want to change user name and pass word
You can do so by opening the GUI page of the router:
First connect it to the computer through a Ethernet wire and then check the default gateway (go to command prompt and type ipconfig)
put in the default gateway address in the internet explorer address bar
Log in to GUI..the default username and password is following
Username: admin
Password: admin
Username: admin
Password: password
Log in and change the username and would also be able to change the wireless password (WEP key) from same
Sep 25, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
I want to unblock the facebook sites
There will be an option on the router's web configuration page called URL blocking or web filtering. Your can unblock it from there. For accessing the router's web configuration page you have to type the default gateway on the brower's address bar. Your can your IE or Firefox.
Steps to find the default gateway
Start->Control panel->network and internet connections->network connection-> Right click Local area connection-> Status->Support
This will show you the default gateway something like
The open Internet explorer type on address bar and unblock the facebook
Aug 17, 2010 | Computers & Internet
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Cannot open web page through router
Try opening network connections TCP/IPv4 on your pc and add ip address manualy to be in the same number match the same as your router ie default gateway and preferred DNS Server eg or depending on what default the router is set on the ip address should be the same apart from the last no. eg or subnet mask will default to the right setting if you push the tab key after entering the ip address
Hope this helps
Feb 27, 2009 | Buffalo Technology WHR-G54S Wireless...
Need to telnet or web into speedstream 5360 modem
I believe the default IP address for those is and the login and password are both admin. If that address doesn't get you to the login screen, do the following.
1. Go to start>run
2. Type cmd and hit enter
3. Type ipconfig
4. Write down the default gateway address
5. Type that address into your web browser and see if it connects to the gui now.
If that doesn't help let me know and I'll keep digging for the manual but wow is it hard to find anything about it online.
Nov 28, 2008 | Efficient Networks SpeedStream 5360 Modem
When I set up the router It comes back with the internet is not hook up, but when I hook the intern et up to the lap top it goes right through Please help me with this problem
try restarting the modem while it is connected to the router. the modem probably thinks that it is hooked straight up to a computer not a router. if that doesn't work go to the web gui by going to the routers ip address on a computer connected to the router. the easiest way to find its ip is to go to run (or the bottom search bar if in vista) and type in cmd. once this is up type in ipconfig /all look for the the default gateway. write this number down somewere.
next go get on a web browser (internet exploiter or fire fox) and in the address bar type in that number. this will take you to the web gui. start adjusting the router so that it works with your internet service.
Aug 14, 2008 | Computers & Internet
IOGear GNS1000 (881317000101) Logo
188 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
