Question about HP OfficeJet D135 All-In-One InkJet Printer
Officejet d135 - "Supply Expired" error message
Display shows "Supply Expired, press Enter to continue, printing stopped, replace black ink cartridge" (did with new #14), "pressed Enter", display "replace color ink cartridge, press Enter to continue" (did with new #14) display "printing" on top line, "press cancel to cancel job" but nothing every prints.
Reset back to factory defaults; (7) Status & Maintenance checked Ink Level (Black 88% - Color 86%) Selected "Clean Printhead; aligh print heads, etc. Each selection resulted in same error message "Supply Expired, ...."
Have cleaned printer heads (copper) with soft cloth, uninstalled and reintalled, etc. Any help would be appreciated.
  • 6 more comments
  • wlfman321 Aug 13, 2008
    supply expired replace black ink cart.
  • JBuck77098 Oct 21, 2008
    The display states "Supply Expired. Printing Stopped. Replace Color Ink Cartridge. Press Enter To Continue." Both of the cartridges have been replaced with brand new ones (not expired). The steps to clean the printhead copper contacts were completed, to no avail. Everything that is suggested in the Reference Guide to have this printer working again has been tried, and still the same message is in the display window.
    Any other suggestions?
  • Anonymous Dec 31, 2008
    Had the same situation with 14 color cartridge. Apparently even if the
    cartridge is from a freshly unopened wrapped package, the machine
    knows the date and it doesn't matter - it won't accept the new cartridge
    and says it is expired!!!!!!!!!! Must be a way to overide this?
  • Anonymous May 23, 2009
    Im having the "supply expired error" also. I was wondering what the cell button looks like so that I can disable it in my printer so I will no longer have this problem.
  • Anonymous Mar 21, 2014
    my printer is only printing documents in blue ink. My color selection is black. How do I get it to print in black again. This is both new and old documents that I have printed before.
  • Anonymous Mar 26, 2014
    installed generic ink. keep getting messages saying ink is expired.
    Replace all ink cartridges and cleaned heads,but still won't print black.Will copy in color.
    printer will not print black ink only colored black ink is full and also tried new one will only print colored ink
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
  • 48 Answers
Cleaning the print heads is an electronic function, NOT a physical one.
Try this link for more Printer Resources
Posted on Aug 19, 2008
I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
Hello there:
This problem is usually due to a print head that needs to be replaced
I have provided the information that you will need ok
best regards mike
This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
  • Low ink levels
  • Ink cartridge approaching expiration date
CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
  1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
  2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
  3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
  4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
  5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
Identifying parts of the printheads Use the table below to identify the parts:
  1. Printhead handle
  2. Printhead tower
  3. Copper contacts
  4. Plastic tape
  5. Ink nozzles
c00064460.jpg Do not touch:
  • Copper contacts
  • Ink nozzles
  • Printhead tower
Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Printing off computer
Most likely your new cartridge has a damaged head. The tiny bit of electronics could have a fault, and therefore not be read properly by the printer. Try taking the cartridge out and cleaning the head with rubbing alcohol - both on the cartridge and the printer - then put it back in. If that doesn't work, try a different cartridge.
Sep 07, 2007 | HP OfficeJet 7110 All-In-One Thermal...
Officejet d135 says bad black printhead- Replace the pentagon --
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | HP OfficeJet D135 All-In-One InkJet...
Supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Jan 20, 2009 | HP OfficeJet d145 InkJet Printer
Scanner failure, black ink expired
As far as the expired cartridge is concerned, Check out the answer at the following link:
http://www.fixyourownprinter.com/forums/inkjet/27744
Cheers,
KAT
Oct 26, 2008 | HP OfficeJet D135 All-In-One InkJet...
D135 expired supply
supply expired, new cartidge installed'
Sep 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Refilled ink cartridges
The reason why the printer says supply expired because the ink cartridge has its own warranty. When the warranty of the ink cartridge has expired then you will get that message. Eventhough you refill it. You need to replace the ink cartridge itself.
Aug 04, 2008 | HP OfficeJet D125xi InkJet Printer
Hp Officejet 7110 Not Printing From Computer
HP 7110 Printer
The problem with the printer is it does not work, there are flashing lights and the message it gives you is to turn the power on and turn it back on. Needless to say when I reboot the system and unplug the printer and plug it back up, I get the same message, does anyone have any solutions to this problem????
Supply expired
So many models. Does this model have printheads under the ink carts? If so, remove the print head and clean the jets with a damp Bounty paper towel. Fold the towel up a few times and blot the head into it a few times to clean out the dries ink.
Aug 09, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
2,215 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
