The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
SOURCE: Have Windows ME Operating system & can't run pc camera software
have you tried connecting a usb cable to your camera?
SOURCE: Cannot load software cd that came with camera
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the USB and run the
software that you downloaded.
The software installer will tell you when
to connect USB.
Some Canon device may not be Vista compatible and cannot work on Vista.
SOURCE: Canon PowerShot S3 IS & Windows 7
This is correct. The S3 is discovered by windows 7 and will allow download of pictures by Windows Picture download. The Canon Utilities software - Zoombrowser - will not work with windows 7 as the software cannot detect the Camera via Windows 7.. Also, Camera window will not start, if using the PC/laptop for remote image recording. If you virtualise XP within Windows 7 this still will not work. The only solution at the moment, if you are deperate, like I was (as I use the Remote Capture process a lot), is to either stick with Win Xp or Dual boot XP on a smaller partition.
SOURCE: Recent;y bought a mew laptop with Windows 2007 as
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
SOURCE: I have a ASUS EeePC
If you're talking about downloading pictures, you can do what the pros do....use a card reader.
Is there nobody out there to help with this one???
