Question about Motorola FV500 2-Way Radio
FV500 Hi Guys, I have a question. I don't know a lot about motorola radios, only about PRO and EP series, I want to know if Motorola FV500 2 way Radio can be programmable in a bandwidth of 12.5 Khz. They need a program like PRO and EP series or I can programm the radio in other way. Please help and tell all about this kind of radios that you know. Thanks.
  • Motorola Master
  • 1,654 Answers
Your FV500 radio has 11 GMRS/FRS 12.5k frequencies pre-programmed into the radio, which cannot be changed. Here is a link to the user guide http://www.giantintl.com/RadioPDFs/manuals/fv500.pdf
You will be limited to the 11 frequencies shown in the upper right of the guide. You could however, reprogram your PRO and EP radios to match the FV500. Note: These frequencies are limited to 1 watt or less.
Posted on Aug 07, 2008
I have a Motorola fv500 brought when I turn it on. The lights keeps blinking with no display. What will be the problem? Thanks.
Batteries. Even on the charger, a shorted battery will cause this. Chargers do not have enough power to allow a radio to transmit.
May 05, 2017 | Motorola Radio Communications
Voltage specs for ch 600 Motorola talk about charger
Hi Patti,
Best I could do is suggest you take your radio to your nearest Radioshack or similar store and I'm sure they will assist you.
I hope this is helpful to you.
Cheers,
Peter
Sep 14, 2012 | Motorola Mobility T4800 T5000 T5500 T6500...
My motorola fv500 reach only 1/4mile
You may have
1) A low or bad battery.
2) Be holding the radio at an angle and reducing your range. Hold the antenna straight up, perpendicular to the ground, to achieve the best range. Height and placement of the antenna determines range.
3) Or you may be trying to talk in-or-out of a building, which would significantly reduce your range. Obstacles between you and the other radio, as well as the body fluid of a person wearing their radio low on their hip can significantly reduce range.
Best regards.
Jun 08, 2011 | Motorola FV500 2-Way Radio
Finding a adapter pin for motorola
Hola
no creo encuentres ese adaptador, Talk about utiliza un plug stereo de 2.5 mm, el audifono que mencionas tiene dos plugs uno de 3.5 mm Mono y uno 2.5 mm stereo.
Tendras que hacerlo y cortar el cable y utilizar un plug 2.5 mm
Jan 18, 2009 | Motorola 2 Pin Adapter 2-Way Radio
Motorola sx500r
I could not find a manual for the SX500, however, here is the manual for the very similar SX700: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
Nov 09, 2008 | Motorola FV500 2-Way Radio
Motorola FV500 - lots and lots of noise on line..
Hello hanshez,
It's also possible that the noise is being caused by local interence. You could try using a different channel. Disable your interference eliminator function and try listening to the various channels to find a quiet one. The interference codes don't actually eliminate interference they just keep you from hearing activity on the channel that can still interfere with your communications.
As long as there isn't other activity on the channel your radios should be able to communcate. Are the radios able to communicate with each other when you are in the same room? Does the problem occur when your son gets further away? Or when he is outside and you are inside? If so, the issue may be one of range.
These kinds of two-way radios are very good for communiations when the users are within line-of-sight of each other. However communications can become blocked by tall trees and buildings, if one user is inside a building or automobile, etc. The 8-mile range that Motorola lists is really only practical when one user has some altitude over the other and clear line-of-sight, such as being on top of a tall hill outdoors with no nearby buildings. For typical communications over relatively flat ground with no obstructions, I would expect a more typical range of less then one mile. Obstructions can lower this effective communications range even more.
Hope this helps.
Ken
"Go Ahead. Use Us."
Jun 20, 2008 | Motorola FV500 2-Way Radio
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Motorola FV500 2-Way Radio Logo
238 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
