SOURCE: Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
SOURCE: Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
SOURCE: HP 6940 will not print
Turn the printer off
Open the back door and
gently turn the paper roller upward until it clicks. Make sure the door is securely closed. Wait a few more minutes then turn the print back on. I hope this helps.
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
SOURCE: washer door opens with hinges on the left
nope sorry but all front load washers are built with a locking system on the door and that makes them impossible to change the door swing.
the only thing you can do is move the washer and dryer position by getting longer hoses and venting so you can have the washer on the left and the dryer on the right.
6 pin socket
6 pin plug
7 pin
socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug
& socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin
round plug & socket
1 left hand turn - yellow
2 reverse -
black
3 earth -
white
4 right hand turn - green
6 stop - red
7 tail, clearance, side
markers - brown
round socket
large 5 pin round plug & socket
3 earth -
white
5 right hand turn -
green
6 stop - red
markers - brown
large 7 pin
round plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
7 pin round
heavy duty plug & socket
1 earth -
white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
5 right hand turn -
green
6 right hand rear , clearance and marker - brown
7 reverse/auxilary -
blue
7
pin flat plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
flat socket
12 pin flat
plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
8 battery supply -
orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
