Question about Kenwood Audio Players & Recorders
3 CD player Kenwood
I have just experienced that the 3CD unit as part of a small system, makes a noise as if it were trying to open, but will not even with a litte pull from me. It is like it is locked shut. I must have at least one CD in there and it does play. Any help would be greatly appreciated. Thank you, Nancy
njwaite@gmail.com
It is a XD-750 mini system with a 3CD rotary disc player
  • Nancy W Aug 10, 2008
    The CD that is still in the 3CD player is stuck in the up position and will not drop down when you stop the CD.therefore the changer will not open.
  • Anonymous Oct 08, 2008
    I have the same issue. The tray won't open. It makes a noise but nohting happens
    Problem Solver:
  • 15 Answers
Dismantle unit and try to open unit look to see if a motor is running maybe it is being droven by a belt or a gear is worn the belt may drop inside the unit. If the belt is worn change it.
Posted on Aug 10, 2008
  • nikole Codrington Aug 12, 2008
    if the cd player carries a belt chk to see if u can turn the gear where the belt was and the cd will drop..
I have no display on my kenwood radio, but it will play the radio fm stations. the cd door will not open either.
Use a small pick tool (like dentists use) to reshape those brass connectors on the back of the face plate. If this model has a ribbon instead of brass connectors it's junk. Make sure where the connectors meet the head unit is clean.
Sep 29, 2010 | Kenwood KDC-MP528 CD Player
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
Aiwa 3cd changer
Click this for free download diagram;
http://www.eserviceinfo.com
If i helped ,please click fixya .It is the only way i get paid...
thank you in advance;
Jul 18, 2008 | Audio Players & Recorders
Rca cd player
The loading mechanism is out of timing. This needs to be taken apart and reassembled. I'll try and locate the instructions for this tonight.
Dan
Mar 20, 2008 | RCA Lawton Turntable with Analog Radio/CD...
Stuck CD
hi there bguedes
best solution take top cover of and as it says pleasewait and you hear the noise just give the tray a bit of a jolt to help it around but beware of electric wires and static that should fix your problem
hope this helps an please if you have the time please rate me if you dont mind
thank you
fixya
Jan 11, 2008 | Kenwood CD-323M 200-Disc CD Changer
XD 313 3CD VCD Player - CD ray not Working
i think u hv chip which is not playing pirated cds,,,,just modify the chip inside & enjoy
Nov 14, 2007 | Kenwood KDC-135 CD Player
424 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
